Tool Talk Discussion Forum
pioneer p26 chainsaw fuel tank pressurizing
Munch
12-14-2003 03:56:47
I have a pioneer p26 chainsaw that runs fine for 5-10 minutes from cold then the fuel tank starts to pressurize. It is pressurizing from the fuel pick up pipe in the tank as air is fizzing out the filter on the end of the pipe. I have stripped the Walbro carb and checked the gaskets and diaphram.These all seem to be ok.Thanks for any help or ideas you can give. Munch
Charles Miksch
01-20-2004 20:10:30
 Re: pioneer p26 chainsaw fuel tank pressurizing in reply to Munch, 12-14-2003 03:56:47
I have an old yellow Pioneer from the 60-70's. It too runs fine for 10min. or so. Then it seems to load up like it is getting too much fuel???
Any ideas???
old
12-14-2003 07:40:15
Most gas caps have a vent to stop that problem, I'd say you need to clean/check the cap and or replace it
m t pockets
12-14-2003 08:14:16
 Re: Re: pioneer p26 chainsaw fuel tank pressurizin in reply to old, 12-14-2003 07:40:15
Take fuel tank,oil tank,air shrouds,bar and chain off the engine.There will be sawdust packed everywhere preventing airflow through cooling fins.Clean and reassemble.This should fix it. MT POCKETS
