Tool Talk Discussion Forum
How to remove a Delta drill chuck
Robert in Md.
12-13-2003 17:52:18
I have a Delta DW953 adjustable clutch cordless drill with a worthless keyless chuck on it. Its impossible to tighten the chuck enough to keep the bit from slipping. I would like to replace the chuck but can't figure out how to get the chuck off. There is a torx screw in the center bottom of the chuck that I have taken out. Now how does the chuck come off. Help please. Robert
Mark
12-15-2003 09:01:31
 Re: How to remove a Delta drill chuck in reply to Robert in Md., 12-13-2003 17:52:18
Mac has got it right. Works every time.
Alvin n Ms.
12-15-2003 06:57:36
Robert, we all have problems with bits slipping its very aggravating at times, but it can prevent serious injury also. Like when the bit hangs (jams) at the break through point, a drill can get very mean, breaking arms, and slapping everything in the area. Try tighten the chuck in all three holes every time you use a bit.(some chucks have four) alvinnms
Mac
12-13-2003 18:23:10
Chuck up the biggest allen wrench it will hold, tap the wrench with a hammer. I always removed them this way.
GG
12-13-2003 18:01:17
I have never removed a drill chuck on this type drill motor but all the chucks that I have delt with, have a right hand thread. The screw in the center prevents the chuck from un-screwing when the chuck is turning counter-clockwise or reverse. If the drill motor is not strong enough to unscrew itself, you may have to use a small pipewrench and tap the handle with a hammer to remove the chuck. The sudden shock should break the chuck loose.
