Tool Talk Discussion Forum
When to hydro-test a compressor tank
BWD
12-11-2003 14:28:36
I have an air compressor that is in need of repair. I am considering a replacement pump, but the tank was manufactured in 1979. It is a 30 gallon tank.
How often should a tank be tested? The tank appears to be in good condition on the outside. When I drain water there are no signs of rust,and there is no structural damage anywhere.
Is there a standard of how often a tank should be tested?
RJ-AZ
12-11-2003 18:04:26
 Re: When to hydro-test a compressor tank in reply to BWD, 12-11-2003 14:28:36
Standard compressed air tank do not require hydrotesting as the are considered low pressure vessels. Only HIGH pressure tanks require testing and I THINK the cutoff is anything over 800 PSI rating.
wrong
12-12-2003 20:10:04
 Re: Re: When to hydro-test a compressor tank in reply to RJ-AZ, 12-11-2003 18:04:26
any pressureised tank requires testing after 10 years if used in an industrial cap. if you dont beleave me check osha and msha
DUH
12-13-2003 20:20:32
 Re: Re: Re: When to hydro-test a compressor tank in reply to wrong, 12-12-2003 20:10:04
Checked the OSHA Regs 1910.169 and it says nothing about hydrotesting an air receiver tank. Only to check that it has a working pressure gauge and safety releif valve. And is built to ASME certifications.
Rod (NH)
12-11-2003 17:00:05
Hi BWD,
It depends. As far as I know there is no requirement for or "standard" time period for hydrostatic testing of privately owned tanks in a non-commercial setting. Otherwise, there may or may not be a requirement for periodic formal inspection and certification as defined by local laws. If such is the case, a formal procedure is usually undertaken by an "authorized inspector" under the National Board Inspection Code of the National Board of Boiler and Pressure Vessel Inspectors or some other entity as designated by law. Generally whether to test and when is left up to the discretion of the "authorized inspector" who has to certify that the tank is safe for continued operation.
If this is for your own use only and no local inspection laws apply to you, a typical procedure would be to test with water only to 1.5 times the maximum allowable working pressure (MAWP) as indicated on the ASME plate tack welded to the tank. You could do this whenever you wanted for your own piece of mind. In any event, check your local and state laws on pressure vessels to be sure.
third party image Rod
jailkeeper
12-11-2003 15:38:55
I've never heard of testing a compressor tank. I do know our fire dept. air tanks (SCBA) are tested every 5 years. Course they are under considerably more pressure (2000 psi +).
Maybe you could find something on the OSHA website if nobody here gives you an answer.
