Tool Talk Discussion Forum
Waste Oil Heaters
Tami Eck
12-11-2003 11:05:03
I am constantly have trouble with my waste oil heater. It will run fine for a while and then all of a sudden it will not run. We have replaced the nozzle and cleaned the entire heater. We have also changed the filter. We do this twice a year. We also had the cats eye replaced today and it still refuses to run. Please help!
Allan
12-12-2003 03:39:43
 Re: Waste Oil Heaters in reply to Tami Eck , 12-11-2003 11:05:03
Tami,
Someone else mentioned this, but it might be worthwhile to say it again:
Check the preheater. Also, that screen at the intake in your tank; It might be setting down in some sludge.
Just a thought,
Allan
kjm
12-11-2003 16:16:19
Tami, What brand of heater?
John R
12-11-2003 15:06:09
Too much oil , not enough cumbustible air will may it rumble. Do you have an automatic damper on the flue? If not get one. These are very similar to the fuel oil furnaces in some homes only uses old oil instead. Oil has to be warmed by heater. Check to see if it is working. Oil has to be clean, no anitfreeze, dirt, sand, ect. I strain ALL of my used oil twice before it gets to the strainer on the furnace. I also have a water seperator between my large storage tank and the tank on my furnace. You would be surprised to see how much water can get into used oil. Chech with your heaters manufacturer and get an owners manual, then follow instructions to the letter. This will save you a lot of time.
JIM B
12-11-2003 14:26:34
HI,I HAVE BEEN HEATING WITH TWO BIG CLEAN BURN WASTE OIL FURNACES FOR 15 YEARS IN A BIG HEAVY EQUIPMENT REPAIR SHOP.A FEW THINGS WILL MAKE THEM WORK MUCH MORE DEPENDABLE,CLEAN OIL,BY THAT I MEAN NO WATER,ANTIFREEZE,SAND, GRAVEL,ETC.YOU ALSO NEED TO REMEMBER THAT THE PUMPS THAT COME WITH THESE UNITS WILL ONLY LIFT ABOUT 5 FEET MAX[THATS MY EXPERENCE]BUT THEY WILL PUSH OIL A LOT FURTHER,THE WAY THEY ARE SET UP HAS A LOT TO DO WITH THERE DEPENDABILITY.IT SOUNDS TO ME LIKE YOURS IS SUCKING AIR IN WITH THE OIL AND NOT STAYING RUNNING,THIS COULD BE A SUCTION LEAK AT YOUR TRANSFER PUMP,I HAVE BUILT A VERY SIMPLE FILTERING SYSTEM TO BE RID OF WATER AND ANTIFREEZE AND DIRT.WHEN THEY SAY WASTE OIL BURNERS THEY LEAD YOU TO THINK THEY WILL BURN NEARLY EVERYTHING YOU PUT IN THEM,WE HAD ALOT OF TROUBLE IN THE EARLY YEARS WITH THEM,BUT NOW THE WORK GREAT AND THERE CHEAP TO HEAT WITH.
Shep Va
12-11-2003 12:41:37
We have one in our shop too and have found that it builds up unburned fuel all around the nozzle about every 200 gal or so that it burns and we have to take the nozzle out and clean it up and then put it back togeather. I replaced nozzles last year and it appears to help, but it still will have trouble every so often.
Dont know how to fix the problem, but I have simular problems, just figured that was the way it is....
Ben in KY
12-11-2003 12:14:25
I think more details are needed on this problem. Does oil get to the combustion chamber ? Does the ignitor appear to work ? Could the oil supply line have frozen water in it ? I have had this happen. Give us more info please as some of those heaters are a bit complicated. Sort of like saying my tractor does not run, what is wrong ?
Tami Eck
12-11-2003 12:20:06
 Re: Re: Waste Oil Heaters in reply to Ben in KY, 12-11-2003 12:14:25
The flame is good. The air pressure is good. The heater rumbles. While rumbling - it shuts off. We think that it is a draft problem. We do have exhaust gases out of the site hole, but not all of the time. We cannot adjust the draft on the side of the burner.
Ben in KY
12-11-2003 12:23:09
 Re: Re: Re: Waste Oil Heaters in reply to Tami Eck, 12-11-2003 12:20:06
Could your exhaust flue/pipe be partially plugged ? Not sure, what is the brand model of the heater ? Someone on here might have fought the same battle.
