Tool Talk Discussion Forum
Dail indicator placement
Wayne
12-09-2003 20:44:09
A few days ago there was a question asked about placement of a dial indicator when checking backlash on a ring and pinion set. The question was does it make a difference wether the dial indicates off the ID or OD of the ring gear. I said it made no difference, that the reading would be the same regardless of where the dial was placed because it was reading a clearance, nothing more. Dennis Minn. and I both placed several posts discussing this and I tried several different ways to explain my position where it could be understood. A couple of the examples I used, I will admit weren't right for this problem as I thought further on it, and that's why Dennis and I kept up the discussion. I don't think I ever really made it make sense to anyone including Dennis but I knew what I was saying was right but just couldn't simplify it enough in my mind explain it like this. So I've thought alot about it the past few days and finally came up with a simple way to explain why the reading will not change, even though the distance to the centerline of the ring gear changes with dial placement. Ok to simplify things to basics imagine both gears are simply straight bevel gears turning the driveline motion 90 degrees to the axels. To illustrate it in 2-D draw two equaliteral triangles (all sides equal length) at 90 degrees to each other (or even two triangles with complimentary angles to equal 90 degrees) with the tips touching to represent the gears. To get 3-D simply make them conical cylinders, which is basically all a bevel gear is anyway. Now to get clearance between the gears/triangles you have to do just like a ring and pinion setup and move the ring gear/ horizontal based triangle along it's axis/centerline to get clearance while the other stays fixed. So keeping on the same centerline, move the horizontal triangle/ring gear down away from the vertical based triangle/pinion . On the actual gear all planes on the one gears teeth are gonna be parallel to the matching plane on the other gears teeth. In this case we're 2-D so there is only one plane/line represented for each gears teeth for simplicity. Ok, the further apart the triangles/gears get the distance/clearance between them is the same wether your at the big end/OD of the ring gear or wether your at the tip/ID of the ring gear. This is because your not dealing with a measurement dependant on a fixed line and a moving line with the same pivot point in which case the clearance would increase with distance from the pivot point. Rather you have two lines that are parallel to and will remain parallel to each other no matter how far apart they get. So at any point along the side of one triangle/gear to the matching point on the side of the other triangle/gear the distance/clearance is gonna be the same, be it .002 or 2'. This being the case, your gonna get the same dial reading on the clearance no matter whether you take it on the OD or ID or the ring gear. Ok, Dennis, and any one else out there wether ya'll were involved in the origional discussion or not, does this example make it all make sense? Let me know. Take care all... Wayne
Wayne
12-10-2003 20:30:01
 Re: Dail indicator placement in reply to Wayne, 12-09-2003 20:44:09
Hey guys, I read all the replys and I agree with and understand all to a point. In answer to one reply, yes I have tried it, and the clearance measurement was the same the same ID and OD. I don't want to beat the proverbial dead horse here and tie up the board, so if anyone wants to carry this on beyond the board in regular e-mail, please write. Like Dennis and I both agreed the first time around, I don't like or want to argue, and don't want or mean to sound like a smart a$$, I just enjoy a thought provoking discussion and the incentive and opportunity to learn and discuss things. That way too I can draw out anything in question and know how to send it as an example of what I'm saying. On that note, do any of you know how to post something like this in a post on here???
Dennis Minn
12-10-2003 21:12:42
 Re: Re: Dail indicator placement in reply to Wayne, 12-10-2003 20:30:01
Wayne, uh, looking back and re-reading our gentlemanly debate, I think we may be discussing two different ideas. Bear with me, I was suggesting the placement of the dial indicator stem would be placed on the outer edge of the ring tooth, in a manner to witness tangential movement of the ring (rotational). Were we on the same page? Seems that the dial indicator witness you were suggesting would be an axial movement? Let me know what you were suggesting again, sure would seem to make sense. Again, regards, Dennis.
Wayne
12-11-2003 21:34:53
 Re: Re: Re: Dail indicator placement in reply to Dennis Minn, 12-10-2003 21:12:42
Heyb Dennis, we are talking about the same thing here. Like I said before I don't want to sound like a smart a$$ but I don't know any other ways to explain this. With the arc angle theory of the ID reading must be less than the OD reading think about it like this. I'll put some degrees of arc angles (DAC) in for refference this time also to make it easier to see. The OD reads .010 (10 DAC) at max and 0 at minimum (0 DAC) This way of reasoning says that ID would have to be less than .010 (10DAC) when the OD is at .010 (10DAC) Correct???? If this is the case, the ID would have to be less (have a smaller DAC) than the OD at all points correct? Now explain if the OD goes back to 0 (0DAC) how is the ID gonna go back to less than 0 (0DAC)???? I have set up many ring gear sets ranging from cars to heavy equipment, to cranes, and I have seen this enough times to know I'm right. I asked Dad today to get a second opinion because he's been doing the same things alot longer than I hacve and I got the same response from him, their gonna be the same. I also asked another old fellow I know that's a machinist and used to build and race cars with Junior Johnson, and he said the same thing. They both also brought up something I knew but I haven't brought up because I didn't want to create any more confusion. That is you can also hold the ring gear and take the reading off the pinion. Whatever the reading you got on the ring you'll get the same off the pinion. Not meaning to be a smart a$$ but for those out there that haven't built a ring gear setup, I understand your being confused here, that's understandable, but for those of you that have done alot of them, I can't believe you don't know this already. If any of you believe me, fine, if not fine, I've run out of ways to try to explain it. I will say this, for those of you that have doubts and don't believe me, try it sometime, I think you'll be suprised at what you find..... Dennis, I really appreciate all the back and forth. The only "threat" I felt was my brain threatening to explode trying to come up with a simple understandable explination to a complex question.HA HA...Stay warm up there in Minn. Take care all.....and have a very Merry Christmas and a Happy New year..... ..... .Wayne
Dennis Minn
12-10-2003 18:09:29
Wayne, I moved houses and didn't have my www set up there yet and kinda lost the thread we were having. Like before, we agreed that all back-and-forth was welcome and friendly in nature for the sake of furthering all our knowledge. That being said, my head still kinda hurts when I get to thinking about all the effort you've been putting yourself through getting ideas onto the screen and into my head so that it makes sense. I truthfully haven't put a whole lot of thinking time into it, but I'll come around, that's a prom,ise and not a threat hehe. Thanks for all the thought provoking discussion, be glad to carry on any old time, Regards, Dennis.
buck
12-10-2003 15:00:50
The measurement being taken in the difference in a held fast pinion to a movable ring gear. The dial indicator will be mounted somewhere other than on the pinion gear so the measurement is in relationship to the dial indicator pointer and the possible motion of the ring gear. All else remaining the same the further form the center of the ring that you get, the larger the measuremnt will be. In an effort to gain the largest contact possible between the two gears the backlash should be measured at the point that this occurs.
Bob
12-10-2003 19:33:29
 Re: Re: Dail indicator placement in reply to buck, 12-10-2003 15:00:50
I like your explanation, Buck!
Bob
12-10-2003 10:48:38
Wayne,
Have you ever tryed this in actual practice? This one's got my thinking a little goofy (Or should I say even more goofy than usual.
I've got a Dorf 9" rear end in the back of the shop I'll get out and check this out in the next day or 2. You had me swayed to your way of thinking, but the more I think about this, I've got to check it out in actual practice!
Anybody else that's set up a rear end lately have a comment on this?
Bob
12-10-2003 11:45:36
 Re: Re: Dail indicator placement in reply to Bob, 12-10-2003 10:48:38
I've done a little more thinking on this...
Pretend for a moment there are no differential gears inside the ring gear, and that a solid shaft passes throught the center of the ring gear and out the side of the axle, and has a BIG degree wheel attached (let's say 24").
I'm sure we can agree that with a given amount of gear lash, for this discussion, assume 0.010", when you rock the ring gear back and forth the amount of the gear lash you will get a certain reading in degrees on the large degree wheel that is an inducation of the amount the central axis of the ring gear rotates for a given amount of gear lash.
So now, we have converted the thousandths of an inch of gear lash to degrees of rotation of the ring gear, with the degree wheel moving with it.
There is no way to explain away the fact that for a given rotation of the ring gear in degrees, which we have determined by experiment, based on the gear lash, the reading of a dial indicator will vary depending on the radius from the central axis of the ring gear/degree wheel to the point read by the dial indicator. Near the central axis of the degree wheel/ring gear, there would be only a tiny reading variation on the dial indicator, and a large (in this case, 0.010") at the outside diameter of the ring gear.
Obviously, if you were to put a pin in the outside diameter of the 24" degree wheel, you would get a reading way in excess of the 0.010 you are reading at the lesser diameter of the actual ring gear.
Therefore, it DOES mater where on the diameter of the ring gear you check the gear lash at with a dial indicator, and this is why MOST manufacturer's instructions say to read the gear lash at the outer area of the gear tooth. In this way, the manufacturer's desired spec's can be duplicated "in the field", because everyone is using the same standard measuring method.
SamH
12-10-2003 05:15:17
I know what you're up against. I have tried to explain what's in my mind on things like this by e-mail and found that it is next to impossible. I've found that what makes perfect sense to me, may not be at all clear to someone else. Please bear this in mind as you read what I say below. I wasn't involved in the previous discussion, so please excuse me if I'm totally off base here.
To reduce clearance, you would move the gears closer together and visa versa, so the two cone illustration makes sense. What you would really be doing here is to set the tooth clearance by checking the end play and establishing the ratio of one to the other.
On the other hand, if you are setting the indicator on the diameter and rocking the gear back and forth, then it would matter where on the diameter the indicator is set because as the diameter increases, the radial distance from one degree of the cicle to another also increases. I believe it's normal to check at the pitch diameter. Another thing to remember with the cones is that the equalateral triangles (sides of the cone) touch each other at 45 degree angles to their axes. Because of that, when you move one of the cones perpendicular to the other, the distance between them will not increase by a 1:1 ratio to the straight line distance the axis is moved, but will increase by the ratio of .70711 times that distance. Does this make any sense at all or did I get up too early this morning?
Skinner
12-10-2003 04:24:07
I'm no expert..... But
I beleive you, that is the reason they are cut as spiral or helical and the pinion is cone shaped. Identical clearance across the teeth and supposivly equal loading across the teeth.
On straight cut gears, I thought the backlash was checked from the center of the gear mesh, or you used wire.
I've checked numerous straight cut gears where the manfacturer tells you told bolt a xx" flat bar to the bolt pattern, and you check backlash so many inches down the bar. That is for repeatability on semi-critical clearances. Waukesha does this on their 4000HP and up engines.
Chris-se-ILL
12-10-2003 14:42:08
 Re: Re: Dail indicator placement in reply to Skinner, 12-10-2003 04:24:07
{quote}"I beleive you, that is the reason they are cut as spiral or helical and the pinion is cone shaped. Identical clearance across the teeth and supposivly equal loading across the teeth."{unquote}
The shape of the teeth is for several purposes, (as was taught to me in automotive school 25 years ago). The pinion is offset from the centerline (radius) of the ring gear to "lower" the driveshaft clearance to the body of the vehicle (and therefore cannot be shaped to straight radial tooth). Furthermore the teeth are helical shaped not to maintain a constant clearance across the face of the matching teeth (the outer edges are gapped farther apart than the centers of the teeth). The teeth are designed to "slide" during contact (the face of the pinion tooth "slides" in correlation to the ring gear tooth. This causes an eliptical pattern on the center of the face of the teeth (as witnessed by the usage of "white lead" or prussian blue). The teeth of each component does not match it's counterpart in entirity (full face) at any point of the rotation. The point of each tooth's contact to its counterpart, (yes, I realize that the teeth do not really touch, because of the lubrication or they would wear out fast), moves as the gears rotate. This sliding action "reduces gear chatter." Straight teeth tend to have more inherent noise.
This all said, the measurement of the backlash is a rotational measurement of the ring gear. Not a sliding action of the ring in the carrier bearings. The ring (and carrier) are not pried from side to side in order to measure the side play of that particular gear (thus testing for looseness in the carrier bearings). The backlash adjustment is a measurement of a circular distance (travel) at a given radius frm the centerline of the axle. As you get further from the axle centerline... the "distance" for a given measure of "degree" of rotation increases. (i.e. Cut a pie into 8 pieces. Take one piece of that pie and measure the distance side to side across the face of the pie at 1" from the pointed end. Then move to the outer crust of the pie and measure across the distance side to side. Though the degree of angle did not change, the distance was increased) As you move out on the radius of the ring gear the backlash ditance of rotation will increase.
Even though there is a given degree of rotation by the ring gear (though quite minute) between either "stop" (from one set of teeth touching to the next set touching, which is what you are measuring). As you move outwardly from the centerline of that measured degree (from the centerline of the ring gear)... you increase the distance between the sides of that degree angle.
Remember, you are not measuring the pre-load of the carrier bearings (side to side movement). The ring gear does not move side to side, it moves rotationally and therefore the measurement of movement around the circumfrence increases as you move outwardly on the radius of the ring gear.
iowan
12-11-2003 12:36:40
 Re: Re: Re: Dail indicator placement in reply to Chris-se-ILL, 12-10-2003 14:42:08
If you take a pencil and put it through the center of a paper plate, rotate the pencil, if you give it 1/2 turn, the plate moves 1/2 turn, but when checking the amount of movement in inchs on the outside of the paper plate compared to the movement of the pencil, the outside movement is greater. Therefore I believe it should be measured on the out side of the ring gear tooth, or in the middle of the tooth. To many formulas and scientific solutions.
Bob
12-11-2003 22:20:04
 Re: Re: Re: Re: Dail indicator placement in reply to iowan, 12-11-2003 12:36:40
You and I know that, but some will never "get it".
If it were possible that the dial indicator reading stayed the same as the point of measurement moved closer to, or farther away from the center of the gear, I'll bet you could do some neat stuff with that setup, think perpetual motion, or time travel. I was almost convinced it was possible the lash measurement stayed the same, and the more I thought about it, the more I realized that theory was impossible. Basic geometry, as you desribe using the paper plate, says the measurement will vary, depending on how far from the axis it is taken, and I see no way to explain that the basic laws of the universe apply differently to an axle ring gear than they do to a paper plate!
I'm still going to set up the Dorf 9" third member I have on the bench as soon as I get a free moment, and verify actual measurements. Come to think about it, I have a large Eaton truck rear that I will be setting up soon. Being so much bigger, the measurements off of the inside and outside of the teeth should vary to a greater degree.
