Tool Talk Discussion Forum
Ford 460 in 1 Ton
Jeremy Brault
12-09-2003 19:27:42
I was just wondering if the flywheel off of a 1983-1987 Ford 1 Ton with a 460 would work on a 79 Ford 1-Ton with a 460. I have a 79 Ford 1-Ton and I am putting a 460 in it. It used to have a 400. My problem is the flywheel though, because Ford never put a 460 in a 1-Ton till 1983. So I need to know if they are interchangable. I would have to think that the cranks are the same. Well any help is a plus.
Thanks Jeremy
magot
02-17-2006 19:54:44
 Re: Ford 460 in 1 Ton in reply to Jeremy Brault, 12-09-2003 19:27:42
1979-97 externerly balanced,1978 & earlier internerly balanced
Trucks
12-10-2003 18:18:04
Ford 460's around '83-'84 not exactly sure were externally balanced, if you took the flywheel off the later model engine you should look at the balancer, if it has a funny looking spacer behind the balancer that is offset like weight it is externally balanced if it just has a smooth spacer it is internally balanced.I know from experience about the weight behind the balancer I recently built a '76 model 460 for a 4WD.You are making a very smart move in dumping the 400 engine or as we called them at the Ford dealership 351Mexico's.(had real bad crankshafts)
Trucks
Jeremy
12-10-2003 20:20:46
 Re: Re: Ford 460 in 1 Ton in reply to Trucks, 12-10-2003 18:18:04
Well, I looked at the flex plate that was on the engine. it is not ballanced. It has no weigts on it. So i ordered a flywheel for a 84-86 460. then I am going to us a tire balancer to balance it. Do you think it will work? obviuosly the automatic was not balanced.
Jeremy
Trucks
12-11-2003 15:02:27
 Re: Re: Re: Ford 460 in 1 Ton in reply to Jeremy , 12-10-2003 20:20:46
I don't know exactly what you mean about using a tire balancer?You need to look at the balancer,not the flexplate as the balancing is done with the weight behind the harmonic balancer.I beleive that you will be safe with your combo.If it is not you'll notice it immediately when you start it up it will shake like a jackhammer!But you're using the same balancer that came on the engine aren't you?If you are the flywheel shouldn't have anything to do with it.Since the auto. didn't have any weights on it and you have the same balancer it should be fine.Let me know how it turns out.
GOD bless you.
Trucks
Mike M
12-10-2003 10:10:52
I put a 460 out of a 1985 in a 1981 that had a 351M. Ford had two differant 460's internal balanced and external balanced. I don't remember what year they did this.They won't interchange unless you would get your engine rebalanced. You may also run into bell housing problems.The later engines used hydraulic clutches. My 1981 had a manual clutch.I should have changed my truck to a hydraulic clutch. Instead I sawed the slave cyl. mounting ear off and redrilled the piviot ball mounting position. The clutch works fine but is hard to push. I really like the 460 pulls great and gets better gas mileage than the 351m.Bought a set of engine mounts from a company that makes them for this job.Had to heat and enlarge the hole for the oil filter in the crossmember ours is a 2wd 460 is longer.
Van
12-10-2003 04:47:00
Check part numbers with a parts department at the dealership. I am not sure but remember something about a change in the way the engine was balanced about 1984.
