Tool Talk Discussion Forum
Overhaul RUST
Jim
12-09-2003 18:16:07
I am in the process of an overhaul. How do I keep those freshly cleaned parts from rusting until I get the engine re-assembled?
Mac
12-10-2003 10:13:13
 Re: Overhaul RUST in reply to Jim, 12-09-2003 18:16:07
Jim: I used to use a product made by "ZEP". Protective coating..
Aerosol cans, spray it on and it leaves a film. Later I started using it on my shovels and things when storing for the winter. The film when dry is sort of tacky, so parts will need to be washed off. They got a web, I CRS!! But google search for ZEP and you can find it easily enuff.
Brian G. NY
12-11-2003 19:21:32
 Re: Re: Overhaul RUST in reply to Mac, 12-10-2003 10:13:13
There is a product called "Fogging Oil" meant for marine use that works well; probably similar to the Zep stuff Mac Speaks of. BTW Zep makes a lot of good stuff!
Bill Smith
12-10-2003 09:57:49
The first thing is the obvious, keep them dry as far as water. That would include condensation and moisture in the air. The second thing is a coating of oil or grease will prevent rust. To tell you the truth, I like to clean parts just prior to installing them. I ussually clean in gas or a cleaning solvant, blow them dry with compressed air, and coat them with oil (I use the same oil that I plan on using in the engine). My reasoning for cleaning just prior to installation is, that way they don't lay around and start accumulating dirt for a period of time before installation and need to be cleaned again. You know how dirt and dust accumulates on your work bench, that's what I try to prevent getting on the parts. Also, good idea to keep blanket over engine when not working on it untill it is all together. Just my 2 cents worth.
rustyfarmall
12-10-2003 05:38:27
Spray them down with WD-40.
old
12-09-2003 20:44:05
put a lite coat of grease on them or STP oiltreatment both will work well
buck
12-09-2003 21:07:50
 Re: Re: Overhaul RUST in reply to old , 12-09-2003 20:44:05
TIP: Keep STP away from all valve train components especially if it is going to be an extended time before operation.
Red Dave - just curious,,
12-10-2003 07:42:04
 Re: Re: Re: Overhaul RUST in reply to buck, 12-09-2003 21:07:50
But, why not? What will happen?
buck
12-10-2003 09:08:06
 Re: Re: Re: Re: Overhaul RUST in reply to Red Dave - just curious,,, 12-10-2003 07:42:04
Just as they claim, this is a coating material that does wanders in older engines. when used on new valve stems, guides, and lifters it can cause them to seize up and now function.
Dick L
12-10-2003 14:09:10
 Re: Re: Re: Re: Re: Overhaul RUST in reply to buck, 12-10-2003 09:08:06
I have been using STP for assembly lube for thirty years and have never had anything seiz up yet.
When do you suppose I can start to have the problem???
buck
12-10-2003 15:44:54
 Re: Re: Re: Re: Re: Re: Overhaul RUST in reply to Dick L, 12-10-2003 14:09:10
On the lite side here. It took me about 30 years to run into the problem and then identify it so you about due. I truely hope you never experience the problem.
