Tool Talk Discussion Forum
Rivett lathe tailstock live-center
E. Frey
12-08-2003 17:05:55
I need to find a live-center for the tailstock of our schools #608 Rivett lathe. They used a three degree included angle for the taper instead of a more common Morse taper. Anyone have any leads for me? I'd really appreciate any info at all!! efrey
Rivett608
01-23-2005 23:05:54
 Re: Rivett lathe tailstock live-center in reply to E. Frey, 12-08-2003 17:05:55
Hi,
I have a Rivett 608 in storage that I'm looking for a manual for. I am currently overseas and cannot access the machine. I found a manual for a Rivett 608-PV for sale, but don't know what the "PV" stands for. My Rivett is a late model one on the metal stand. Any help would be greatly appreciated. Mac
wallyb70
09-25-2005 18:42:33
 Re: Rivett lathe tailstock live-center in reply to Rivett608, 01-23-2005 23:05:54
hi mac, the PV means v pulley and a PC is for cone pulley. i need a tail stock for my 608 if you hear of one. thanks, wally
george md
12-08-2003 23:33:28
E.Frey,
MT is about 3 deg included angle .MT's are
not all the same varying .5986 to .6256 per ft.
5/8 per ft converts to 2 deg-59 min-3 sec. I guess the real question is what is the dia
of the hole in the large end of the tail stock spindle ? I have a set of MT reamers that goes from #1 to #5 . Either I can send you the reamer or you send me the spindle and I'll do it , that way you can get the tooling you need.
george
Davis in SC
12-08-2003 21:44:54
Must be a Brown&Sharpe or a Jarno Taper. Not common now, but should be some on ebay..... .Rivett made some nice lathes
wdTom
12-08-2003 17:17:51
Maybe it would be a good class project to make one. Machine taper, bearing housing etc., and hardend and temper the nose.
kraig WY
12-08-2003 17:11:56
Ever thought of maybe machining the tail stock to take the morse taper since most of the tools for tail stocks are for morse tapers anyway. Just an ideal.
Al m
12-09-2003 15:35:17
 Re: Re: Rivett lathe tailstock live-center in reply to kraig WY, 12-08-2003 17:11:56
yes,I agree with Kraig,chuck the apropriate morse taper reamer in the headstock and put in lowest gear.slide tailstock up to reamer,clamp,then use the tailstock feed wheel to feed into the reamer.
Al
