Tool Talk Discussion Forum
Winch Question
Tim
12-08-2003 16:32:43
I have a 6000lb Minn. Moline I take to shows and local pulls. I have a Dodge Cummins and a Big Tex 20 foot gooseneck with a 5 foot dove tail to haul the tractor.
Just in case this big Minnie decides it doesn't want to run one day, I'm considering buying a winch. Unfortunately, I don't know beans about them. I'm looking to spend around the $600 mark to get a good one. (I read good things about Ramsey.)
I want to mount this to my trailer and use the 2 batteries from the Dodge to run the winch.
Any suggestions about size, brand, and how to mount would be appreciated.
Thanks A Lot.
Catskill Pete
12-11-2003 09:56:43
 Re: Winch Question in reply to Tim, 12-08-2003 16:32:43
After much trial and error what I have found works best with my trailer mounted winch, is to set a battery on the trailer deck connected to winch.[shortest possible leads]. Then I connect my jumper cables to the battery. As the others have posted voltage loss from long cables is the problem. Low voltage at winch motor causes the motor to overheat rapidly, and lose power. The extra battery seems to take care of most of the problem. As to size, I have a Ramsey 8000 that has handled any thing I have tackled. Biggest tractor so far is a JD 2955 with cab. No matter what size you get you will always wish you had a bigger one! Unfortunatly as you go above 8000 the prices start to take big jumps,so I guess I'll just have to live with it.
Robert in W. Mi
12-10-2003 10:58:26
Maybe you wouldn't want to do what i did, but i mounted my 12,000 single line Warn in the front bumper of my truck. Then i also put a hitch in the front bumper too. "If" i need to winch something onto my trailor, i just turn my truck around, hitch up, run the winch line out and winch what ever onto my trailor.
It's a lot easier to get into tough places hooking the trailor onto the front and pushing it into place, and when i'm just useing the pu, i have a winch to get me un-stuck.
It keeps all the electrical short too.
Robert
Farmered
12-10-2003 04:04:55
Tim, Don't get the idea that I am knocking the winch. I say the more tools a person has, the more options he has. You will find that you have a lot more uses for the winch after you have it.
Just follow Ken Cs advice on cable, it's a long way from those big batt's up front back to the trailer. (from a fellow Cummins operator) Ed
Farmered
12-10-2003 03:48:12
I have a one ton cable come-along which I have had forever. I have retrieved dead tractors and loaded all kinds of stuff with it over the years.
If you are thinking only emergency use I'd go with it over the winch. If you go with the winch, better have a come-along with you just in case. Ed
Ken C.
12-08-2003 18:49:34
Hi Tim, I do a bit of jeepin', have seen Ramsy, Warn, Milemarker and some others out there. Any of those would work OK. Mine is a Warn M8000, my "jeep" (Willy's Truck) is over 4500lbs. and the winch has pulled it out of some pretty rough stuff. I have also used it to pull a couple of pickups onto a gooseneck, no problem. I built a mount for mine that slides into a hitch reciever, ran 1/0 welding cable from the battery's to both ends of the Willy's & used taper pin welder plug in's to connect to power.
George
12-09-2003 20:30:52
 Re: Re: Winch Question in reply to Ken C., 12-08-2003 18:49:34
The biggest problem I have seen with winches is keeping the voltage drop between the battery and the winch to a minimum. As an alternative to Ken C.'s method, I have long one-piece cables running from the winch to the truck's battery. This cable is stowed in the trailer's tool box. At the battery end I installed extra long bolts for the battery clamps and wing-nut the winch cable lugs for the electrical connection. Yes, I have to open the hood to connect up the winch, but it is really easy to equip a second truck to pull the trailer and operate the winch.
Greg Or
12-08-2003 18:36:49
HI Tim
I built an H-frame style [two center bars in the H] mount out of rectangular tubing & incorporated 2" receiver material as part of the locking or hold down system allowing the winch to be removed when not needed. It also allows the use of a ball or pintle for a block & double line [just plain handy]. If I knew where?? or if you might interested I would post a picture or two.
BTW, The winch is a Warn 8000, its what I had.
