Tool Talk Discussion Forum
Tank to pre-lube rebuilt engine.
Steve-Maine
12-06-2003 15:57:45
I have always borrowed what I call a pre-lube tank to put oil pressure throught oil galley to a rebuilt engine but the shop closed. Has anyone built one of these units using low air pressure?
Thanks
HJP
12-08-2003 17:06:20
 Re: Tank to pre-lube rebuilt engine. in reply to Steve-Maine, 12-06-2003 15:57:45
The bladder in the brake bleeder is to prevent air from contaminating the brake fluid.micro air bubbles would make bleeding almost imposible.
Van
12-07-2003 20:04:39
Made one from a old carry around oxygen bottle. Just has a 1/4" hydraulic hose attached at the end with a ball valve and mail air fitting at the other end of the hose. I take the hose off and fill it with a funnel, screw hose back on and presurize with shop air, close ball valve, have a fitting for oil galley on motor with a female air QD on it. The I hook up tank, turn it upside down and open valve, works great. also have another that holds 3 Qts of rearend lube. Can fill up a rearend or transmission in the time it takes to remove the plug, no more sqeeze bottles!
Earl S.
12-07-2003 14:16:16
Visit Goodson at www.goodson.com they have engine pre-lube tanks.
Steve Crum
12-07-2003 08:09:22
I used to have several old distributors for various makes and model engines that were reworked in the lathe to remove gear teeth advance mechanisms etc. I could put one in the engine and run the oil pump with a stout 1/2 electic drill to circulate the oil thru the engine and insure the pump would build acceptable pressure. On the engines were this wasn't practical, everything was slicked good with STP and the engine started as soon as possable after installation. Never let a "fresh" engine set more than a week before being started especially if it's going to be stored. Get the engine up to temp so the oil can impregnate all the pores and spaces that were cleaned out during hot tanking and other cleaning work. Otherwise you could end up with a lot of internal rust to wash off and circulate with the oil. I've even torn down new crate engines for a look see and found areas that need cleaned up prior to installation.
hay
12-07-2003 03:20:17
many years ago when i was into engine rebuilding and hot rodding, i used a white grease that was liberally mopped on the crank journals and bearings before anything was assembled. acutually i mopped it on anything bearing surface so it was lubed before the oil pressure came up when first starting. it was called LUBRIPLATE. i found some spray white grease recently and it works even better than hand brushing because i can spray up into tiny oil passages. i have seen some mechanics use STP and regular motor oil also.
Chris
12-07-2003 06:22:34
 Re: Re: Tank to pre-lube rebuilt engine. in reply to hay, 12-07-2003 03:20:17
The spray white grease is too light to be a real good assembly grease.Use an assembly lube. And I wouldn't recommend spraying white grease into small oil passages as it congeals and could partly plug a passage at startup. You really should pump you engine full of the same weight oil you are going to run in it. That is the purpose of the pressure tank. To purge air and fill all the oil passages so she has oil flow immeadiately.
Wayne
12-06-2003 21:59:53
Hey Steve, we have one, probably like you used to borrow, made out of a small horizonal tank with a regulator to control the air pressure going in and a oil line to hook to the block coming out. Honestly though it mostly sets under the bench unused. I've build or helped build a good many engines in the past few years ranging from a small 4 cyl Yanmar to a big inline 6 cyl D353 out of a D9G CAT dozer. The only thing we do is prelube as we put them together. We always use STP or equivilent mixed lightly with some 30wt oil,(use just enough oil to make it fluid where you can brush it on without to much stringiness). If you'll coat everything as you put it together the lube will stay put and prevent a dry start on a rebuild. Then all you need to do is when your actually ready to start the engine leave the fuel off and turn it over a little bit without letting it crank and run. This way you let the oil pump itself build pressure and lube everything "properly", and since it was prelubed at assembly nothing is ever run dry. Dad and I have done many of them like this and haven't had one come back on us yet.
DaveCA
12-06-2003 16:45:17
Yes, using a cheap garden sprayer or one you already have, of course making sure it's clean. Just need a barbed hose/NPT adapter to oil galley, add oil and pump it up.
Catskill Pete
12-07-2003 09:58:48
 Re: Re: Tank to pre-lube rebuilt engine. in reply to DaveCA, 12-06-2003 16:45:17
Dealership I worked at[long gone] used a brake bleeder. Basically a pressurized tank filled with oil, worked extremely well. I have searched for quite a while but never found another like it. That said I have been thinking of making one out one of my old propane tanks. Sure would like to hear from anybody who has done it.
Slowpoke
12-07-2003 21:50:00
 Re: Re: Re: Tank to pre-lube rebuilt engine. in reply to Catskill Pete, 12-07-2003 09:58:48
Doesn't the brake bleeder tank have a bladder in it? I think the brake fluid is in the rubber bladder to keep the tank interior from rusting. Or is the fluid in the tank and expelled by the bladder to keep air out of the fluid? Would 20-30+ lbs air pressure rupture the bladder?
I recently got 3 of the old stainless steel, 3 gal water pressure fire extinguishers. They have a large opening, pressure gauge, air fitting and hose. Fill with water, air up and go. They operate at 100psi, and will push the water out 30'. It should work for oil, too, at a lower pressure.
The only problem is finding the correct threaded fitting if you want to replace the hose with pipe, etc. The manufacturers like to use oddball fittings so one can't change things easily, but I managed to adapt one to 3/4" pvc pipe. I guess one could cut the hose and use a barbed fitting to pipe, but I didn't want to destroy the hose.
Catskill Pete
12-08-2003 16:08:18
 Re: Re: Re: Re: Tank to pre-lube rebuilt engine. in reply to Slowpoke, 12-07-2003 21:50:00
No I don't think it did have a bladder in it. I dont't remember any evidence of it when I was filling it. However 1. the memory ain't what it used to be. 2. It may have had a bladder in it when it was new, but it disintegrated. That may be why we were using it to lube engine not bleed brakes, although being an IH farm dealership back in the mid seventies I don't remember a whole lotta hyd brakes to bleed. What we did was to fill it with oil, pressurise it then turn it over and open the valve. As I remember we used about 45psi. Worked slick.
