Tool Talk Discussion Forum
Mapp gas...worth the cost?
Jerry A.
12-05-2003 18:25:54
Just bought a Bernz-o-matic self igniting burner/torch that also works with MAPP gas. I've only ever used propane before.
What are the pros and cons of MAPP gas vs. propane? Is it worth the extra cost? (at least twice the price for the same size bottle).
Any input would be appreciated.
TIA
Doug
12-09-2003 16:32:23
 Re: Mapp gas...worth the cost? in reply to Jerry A., 12-05-2003 18:25:54
When sweating copper pipe, I use the MAPP on 3/4" and larger pipe, makes the job go faster, easier. Propane for 1/2" and smaller pipe. The MAPP seems too hot for 1/2", burns the flux out too quick. JMHO
John
12-07-2003 09:30:42
once youve used MAPP gas, you'll never go back. I use MAPP when soldering any pipes bigger than 1 1/2 inch. it gets the job done a lot faster. MAPP is a stabilized form of acetylene. your supposed to use a special torch for it, but i ust use a popane torch.
Vern-MI
12-06-2003 04:09:34
From the web:
(C3H4) MAPP neutral oxy-MAPP Gas flame produces a 5301� F flame temperature. MAPP-air flames also produce better results, much faster than air-propane.
(C3H8) Propane produces an optimum flame temperature of 3500�F.
John K
12-05-2003 22:13:27
I use propane for regular soldering, if I need extra heat, I use Map gas. When silver soldering copper lines for refrigeration, I use Map gas.
JDK
12-05-2003 19:19:39
MAPP burns considerably hotter,will allow light brazing and heat parts quicker due to higher output,also for heavier soldering jobs.I normally use propane in my Shurfire,but keep a couple Mapp bottles on hand for special use.
JT
12-08-2003 11:38:15
 Re: Re: Mapp gas...worth the cost? in reply to JDK, 12-05-2003 19:19:39
I had heard so much about the MAPP gas I decided to try it on silversoldering some 1/2" copper pipe. I managed to get the L's and couplings soldered (It seemed like it took forever) but I never did get a T hot enough to melt the silver solder - finally drug out my acetylene torch. I was using one of the new torches designed for MAPP and I held it on the T till my arm ached. It never did get hot enough. Took about 15 seconds with the acetylene. As far as I'm concerned I wasted $40.
JT
