Tool Talk Discussion Forum
Plastic Pipe
Alvin Wilkinso
12-04-2003 07:15:12
Has anyone installed schedule 40 PVC with a tractor and subsoiler? Do you weld a pipe to the plow, to feed the pipe through? I have heard about it, but never been there.Thanks alvin n ms
Florida boy
12-06-2003 20:21:00
 Re: Plastic Pipe in reply to Alvin Wilkinson, 12-04-2003 07:15:12
Have done wire and 3/4 PVC using one prong of a chisel plow. The secret is to glue your pipe together before starting and pull it in. You need an adapter that can be made using 6 inches of chain and tapered piece of pipe. The adapter I use is a piece of pipe that goes from 1 in. to 2 in. in about 4 in. The chain attaches to the bottom bolt on the chesil plow and goes thru the tapered pipe and attaches to a bell reducer that I belive is 1in. by 2in. To install pipe dig a hole at the starting and stopping point. Have enough pipe glued together with a male adapter screw the pipe to the bell reducer on the end of the chain. Have pipe lined up behind starting hole drop chesil plow in hole and drive pipe will follow. This works really well in Florida sand.
Richard Fazio
12-04-2003 16:35:08
I'm going to try the same thing for a water line to the barn. It won't be deep enough for freeze protection, but that's ok. The barn isn't heated all the time anyway and I have to drain it down. But it will make it quick and easy I'm hoping. I want to try laying direct bury romex this way too. From the barn to a shed about 300 ft. Sure would be faster than trenching.
kyhayman
12-04-2003 11:44:03
Cant see putting in PVC that way. I've put in a lot of the black coiled pipe that way (Orangeburg Brand. Comes in 400' coils. Sizes from 1/2" to at least 1-1/2. All I've ever used is 3/4 and 1". I still like using a ditch witch the best. Laid water line to the house where my folks live that way (about 650'.)
Local code here requires PVC for household use to connect to meter so you have to trench it and get it inspected with the trench open. Last couple I did were PVC to a mobile home and then a check valve and 1" black to the rest of the farm. I still like to rent a ditch witch to bury line, I want to charge it and check my fittings.
gspig
12-04-2003 11:19:53
Seems to me the person that told you meant poly-butyl. It is a black pipe that comes rolled in a coil. I have seen pictures of some setups using a middle buster with a bent pipe welded to it used to trench and place the poly. Water supply poly-butyl is 3/4".
Paul Janke
12-04-2003 07:51:50
I doubt PVC would work. The PVC I am familiar with is relatively rigid and threads together. The plastics which come in a roll use slip in fittings and hose clamps and would probably work. Now we'll wait to hear from somebody that really knows. The dealers in the stuff can probably give good opinions if not sure answers.
Alvin n Ms.
12-04-2003 19:00:13
 Re: Re: Plastic Pipe in reply to Paul Janke, 12-04-2003 07:51:50
Posted by Phil in MS on December 04, 2003 at 14:00:32 from (207.203.128.29):
In Reply to: PVC Pipe Instalation posted by Alvin Wilkinson on December 04, 2003 at 07:12:55:
Alvin,
A friend and I have laid pvc pipe several times using a subsoiler. First plow your route several times. Then tie a wire to the bottom of your subsoiler. Glue your pipe together and let it set about 5 minutes or so. Tie the big end of the pipe to the subsoiler foot and stuff a rag into the open end to keep dirt out. He did weld a nut or cut a small hole at the bottom of the foot to keep the wire from riding up as the pipe is pulled. Start your tractor moving and let the plow down and the pipe will feed itself. About all the digging you will have to do will be at each end to attach to water source and to attach to outlet. You will be able to pull several sticks without any problem. We put water to my barn and we may have pulled 120 to 130 feet. We also pulled to his barn which was about 350 to 400 feet from his source. I don't recall having a problem but we did do two pulls of about half way and then did a splice in the middle. I don't think you will have any problems unless your real close to several buildings or other obstacles. In North Mississippi you only need to be 10 to 12 inches deep and depending on your plow you should be able to get that deep or deeper. If your in a colder climate you may have problems getting deep enough with just a plow.
Good luck.
Alvin n Ms.
12-04-2003 08:20:25
Thanks Paul, for your reply. I don't see how it could work myself. Seems like it would break that schedule 40. alvinnms
