Tool Talk Discussion Forum
fuel smell/leakage
Denise
12-03-2003 17:18:33
After my 96 dodge caravan is warmed up, then you take off from a stop,(not just the first time starting off) you occasionally have a strong raw gas smell. This evening, I got out and looked and saw a spot on the ground which smelled like gas. What do you think my problem is? Would like to self fix it(have 1 1\2 mechanics in the family and they aren't sure what to say about this as they aren't dodge masters. 3.0 litre eng.
Open minded to all suggestions,will put them all together, then figure out what to do.
Thanks, Denise
fred kobs
12-04-2003 23:12:36
 Re: fuel smell/leakage in reply to Denise, 12-03-2003 17:18:33
Has anyone recently put a fuel filter on it?? If it's origional,it may have died of natural causes, and if it's been replaced in the last couple months, Wix and some other brands had a problem with leakage. It's a plastic filter with 3 plastic lines coming out of it. I know Wix was quick to cure their leak prob. and will replace for free if it's theirs. Just a thought. Fred
jed
12-04-2003 10:24:47
I had a problem like that with a pickup truck. I would occassionally smell gasoline after pulling out and then it got to be all the time when I pulled out. One day I was driving on a full tank of gasoilne and I noticed that the gasoline gauge was going down quickly. When I got home I opened the hood with the truck running and saw a spray of gasoline coming from the side of the fuel pump. Turns out that the diaphram had finally completely ruptured and the gasoline was being pumped out of the vent hole in the fuel pump. I never noticed it before because I never checked with teh engine running.
Mac
12-04-2003 08:21:40
You might want to go to alldata.com. Check TSB's and recall data on that model. Maybe ask dealer to check them for you. Raw gas is nothing to mess with. I looked at alldata and saw a couple items pertaining to possible raw gas leaks. You didnt say what motor, but I think what I saw apply's to all 96's regrdless of engine size. Hope this helps ya. Try to get it corrected pronto.
Bob
12-04-2003 07:42:25
This is nothing to mess with. Unless you are VERY mechanically inclined, and can fix this NOW, get it to a dealer! There may even be a safety recall on it. Money's tough to come by, having the family burnt up in a gasline explosion wouldn't be too great, either!
Bob M
12-04-2003 04:18:28
Denise - My daughter's '91 had the same problem. Turned out to be badly rusted and leaking connections at the fuel filter. Replacing the fuel filter and filter connection fittings cured the problem.
Filter is located under the car on the passenger side, about midway between the front and rear wheels.
Mac
12-03-2003 19:15:46
check fuel rail/connections for leakage. You may also have an injector seal leaking. If the drip is at the rear, check the filler hose clamps.
