Tool Talk Discussion Forum
Using C frame tool to replace lower ball joint
Tom
12-02-2003 06:44:13
Dang, guys. I accidentally posted this message onto the tractor board instead of here. So, here it is again.
I need to replace the lower ball joint on my Ford 250 Heavy Duty, four wheel drive pick up. The Chilton's manual says that I need a C frame tool to press the old ball joint and to press the new one in. Since it's a four wheel drive, it doesn't use control arms, it uses a cast iron steering knuckle. I called the local Ford dealer and they said they would be willing to part with one of theirs for about $500. A guy on e-bay is selling a "univeral" C frame tool for about $100.
Any experience with pressing lower ball joints in or out? Any experience with "universal" C frames?
Thanks,
Tom
Tom
12-02-2003 22:22:02
 Re: Using C frame tool to replace lower ball joint in reply to Tom, 12-02-2003 06:44:13
Thank you all for the great information. I'm probably going to buy one of the tools mentioned in the responses and give it a try.
You guys are the best.
Tom
Jay
12-02-2003 20:24:40
You can go to your local Autozone and rent one from their loan-a-tool section. It's about $99 and when you return the tool you get your money back.
Tibs
12-02-2003 17:47:02
I have this ball joint press and have had very good luck with it.
Link
Used it many times on Ford F150's and on my own F250 with TTB suspension. There are accessory kits for this press with more adapters/sizes to fit various applications. I use the standard unit and use metal scraps or sockets if I need to work around the ball joint stud or need extra throw. Tool is also good for U-joint work and to press out studs, etc. I find it well worth the money!
good luck
S.T.
John Ne.
12-02-2003 15:26:01
Just like Ron, I've been doing it with various pieces of pipe/adaptors, and made a punch, 1 1/4 x 8, out of a tierod. Using a 4lb hammer, persuades the old balljoint to move. The ball joint press tool, C-frame? never heard it called that, but then only been working on cars 40 years, have used them, but also had them fail on me too. Basically an extremely heavy C-clamp, with threaded end about an inch in diameter. If you do pull the knuckle off and put it in a shop press, support it extremely well, and wrap safety canvas around it too, as 15 tons of pressure can cause stuff to fly across the shop a bit on the quick side. Use plenty of wd-40 or your favorite lube, Also when pounding on the axle, support it well with a jackstand, as the blows are lost if the axle is dangling on the springs. John in Nebraska
Ron in Nebr
12-02-2003 15:08:38
I've replaced dozens of balljoints through the years while working as a professional mechanic, and I've never used any special tool. On the 4x4's, I always take the knuckle off(gotta remove the spindle snout then pull the axle shaft out, remove the balljoint nuts, and hit the solid part of the axle housing that the tapered balljoint shafts go in with a hammer until they pop loose).
Then, once the knuckle's off, adjust a bench vise so that it's just wider than the balljoint but the knuckle still rests on it, and a few whacks with a large hammer has it out. Don't forget to check for and remove any C-clips that might be holding the balljoint in. To install the new one, first lightly scuff the inside of the knuckle with scotchbrite to remove any rust/crud that might be there. Get a socket large enough to cover the stud on the balljoint but still rests on the shoulder, then use the vice to press the new one in. It may take some readjusting to get it going at the proper angle, and sometimes having 3 hands would be nice while juggling all the parts, but once it's going in straight it should go pretty easy. If won't go far enough, I've found that a used bearing race works good to put on the other side of the knuckle to allow the balljoint to go in fully(kinda hard to describe but you'll know what I mean when you're doing it). You may have to tap the vice a couple time to get the balljoint to fully seat. Also, be sure to not have the grease boot on while you're pressing it in! Then reinstall everything and you're done. It sounds complicated but it's pretty straightforward, I can usually change both balljoints on one side in less than an hour doing it this way. One final thing- when removing the spindle snout from the knuckle, take note of whether there's a tapered shim in between them, and if so be sure to re-install it the same way it came out, since it'll affect alignment if it's not in the same way it was. These aren't very common but I've run into a few. Good luck!
buck
12-02-2003 12:32:36
The key to the C frame tool is to have the correct adapters for the vehicle that you are working on. The quality of the c frame itself is also vey important.The link that someone else posted list the application for that particular group of addapters. a stand along C frame is not going to be much use to you. I purchased one of these outfits about 15 years ago set up for the vehicle that I worked on.(VW bugs).I drove it with a 3/4 impact and it got a lot of use and never failed. Heavy lubrication and frequent cleaning is important. To tell the truth , when working on a difficult ball joint I would get the feeling that all he!! was about to break loose. Assumuming the tool in the link provided by others is a good quality tool then it is a good deal. Another good aspect of the addapters is that they can be used in your regular shop press for many other applications. good luck
tech4
12-02-2003 11:30:07
Here is a link to one place that has the tool for $75.66 scroll down to see tool
ScottT
12-02-2003 10:20:14
I have always managed to get balljoints out and in with a hammer, various punches/socket, perhaps a c clamp and a torch. Yes it is quite a hassle. It would be easier if the knuckle were removed from the vehicle.
Scott
John K
12-02-2003 07:06:55
I bought one at Princes Auto here in Alberta for about 80.00 Canadian for the C frame tool and adapters.
Bob
12-02-2003 07:03:41
We use a 20 ton shop press. Press the lower joint in first, using a hollow driver inserted through the upper ball joint hole. Then press the upper joint on. With an assortment of press plates, and various pieces of scrap bar stock is is not hard to properly support the knuckle.
