Tool Talk Discussion Forum
Welder for pipe fence advice???
richard
12-01-2003 10:43:30
I'm going to start putting up some pipe fence around my property. I guess I need a tourch for cutting pipe and saddles, but I am a bit up in the air about welders. I'm sort of leaning towards stick welds because of price. I can get an Lincoln AC/DC stick welder for about 350 from Home Depot, but I still need a generator. They also sell a Power Arc 4000 stick welder and generator for a bit over 1,000 dollars. Any on have any advice opinions???
KX
12-02-2003 07:45:50
 Re: Welder for pipe fence advice??? in reply to richard, 12-01-2003 10:43:30
Richard,
A chop saw would be better than a torch for cutting saddles. You didn't say what type of material you are going to be using but I have done quite a bit of fencing, entrances and built a corral out of 2 3/8, 2 7/8 drill stem pipe and 3/4 sucker rod. To saddle the pipe to fit on another pipe, I use approx 35 degree cuts. The piece saddled at 35 degrees on both sides leaving a high points will straddle and weld nicely on another piece of pipe of the same size. To saddle a bigger piece less angle to saddle smaller more angle. You want to fit this as tight as possible so your weld will seal off good preventing water from entering the pipe later. That will make your fence last for years as long as you keep it painted with a good oil base paint to prevent rust. trying to saddle with the torch, you wil either leave gaps or spend lots of time trying to fill with the welder. Building it to last is key, you wouldn't want to do it over in 5 or even 10 years. As for welders, I would recommend a portable gas powered stick welder like a SA200 or Ranger 8 or Bobcat. Trying to use a buzz box in the field is pretty difficult. you can find used portables in classifieds, eBay etc reasonable.
Richard
12-02-2003 14:03:15
 Re: Re: Welder for pipe fence advice??? in reply to KX, 12-02-2003 07:45:50
I'm thinking of using drill stem pipe. Probably be welding 100 feet at a time. Just a question: don't you want to cut the saddles in the post once they are in the ground. If you were going to use a chop saw would you need to do it first before setting the posts. I can see how to 30 degree cuts would make a nice saddle.
KX
12-03-2003 07:22:38
 Re: Re: Re: Welder for pipe fence advice??? in reply to Richard, 12-02-2003 14:03:15
Richard,
I saddle the posts as I set them. Then when setting, level with a string or laser level. I try to run the toprail more level than with uneven ground so some posts are longer than others. If you make all posts the same length, it can make putting the toprail on a big pain. In my corral, it is 5 1/2 feet high on the front and amost 7 in low spots and on one side. My neighbor said if you have one go over that, let him go. The beauty of the drillstem is you can screw it together and get a infinite length of pipe with a seam that won't ever seperate. Just try to avoid a joint end from laying in a saddle. email if you want to talk further.
Keith
BFO
12-02-2003 05:17:45
Just bought my second Lincoln Ranger 250 yestarday, can't say enough good about this machine.
T_Bone
12-01-2003 15:50:27
Hi richard,
For building pipe fence you need a 0"-2" Ridgid pipe cutter (manual not powered) a Mig machine with flux cored wire, a pipe saddle notcher, pipe cutting vise, pipe v-clamp, side grinder, torch.
Depending on what size pipe your going to use and how much fence you need, will determine if any of the above tools can be changed or elimated.
The pipe cutter, cuts the pipe square every time and you need the pipe vise to hold the pipe while cutting.
The pipe notcher saddles the pipe so a butt weld can be easy done. If your using 1/2" or 3/4" pipe you can also smack the pipe ends on both sides, sligthly closing the pipe for a fairly good fit for welding. It does however look just like it's described when done, a smashed pipe joint, where as a saddle notched looks more professional and smooth flowing. You might want to try a small piece to see if thats what your wanting for a finished look.
Welding small diameter pipe with Mig is much faster and easier than stick welding. You 3 point tack the pipe then weld vertical down on both sides starting at the top center. This produces a flat weld with very little dingle berries (highly techincal term). The flux cored wire works well as you don't need a cover gas in the open air.
Can you use a stick machine? sure can! About 1/3 to 1/2 slower than Mig in this application. 7018 would be a good choice. If Time is not a object, then this is more cost effective. The welding techinque stays the same no matter what process is applied.
Depending on what machine you choose, a new portable welder might be more cost effective than a generator/welder combo. If you make a good buy on the machine, then it might pay to sell the portable machine when done then buy a kick around machine. Ya right, as if I'm going to sell a nice protable machine when I'm done!
The pipe v-clamp is for holding the pipe straight when joining lengths of pipe. It looks like a piece of angle with two clamping chains with a notch to weld the pipe.
A Makita 5" side grinder with 4.5" wheels and cupped wire brush for finish touch up.
A Victor 100 mixing body is about the finest torch made. Easy to control with less hand fatique. I still perfer Oxy/Acet mix although the propylene/oxy mix looks interesting.
T_Bone
Richard
12-02-2003 06:08:34
 Re: Re: Welder for pipe fence advice??? in reply to T_Bone, 12-01-2003 15:50:27
T-Bone:
Thanks for the information. Just a few questions. Can you suggest a good brand for a saddle cutter? Can you use a tourch to cut the pipe to length and make saddles or is this not done???
T_Bone
12-02-2003 10:22:04
 Re: Re: Re: Welder for pipe fence advice??? in reply to Richard, 12-02-2003 06:08:34
Hi Richard,
Depends on the pipe size? Pretty hard to suggest an exact method without knowing just what your doing, size? length?
If your only going to build 200ft of fence then it's not worth buying a bunch of equipment. Give me a torch, welder, grinder and a couple pair of finger grips, and I can build alot. Fence and handrail however can get boring really fast and why I suggested the additional tools.
On smaller pipe, I've used a side grinder to cut saddles as it's much faster than using a torch. I've also used KX's method with a cut off wheel.
I have not bought a saddle notcher and it's been too many years since the last time I used one to suggest a brand name. I see Northern Tool sells one tho. quality??
T_Bone
old
12-01-2003 11:16:07
You will need aprotable welder for what you want to do, If you watch at auctions you should be able to find a good one pretty cheap saw a hobart go for around $250 last year it just needed a little TLC it hadn't run for about 2 years but I know the guy stole it for that price
