Tool Talk Discussion Forum
Threads, what Type?
Hendrik
12-01-2003 02:10:06
Need to re-tap a few threaded holes in parts of my 1948 Farmall Super A. Since I am in (a) metric country (The Netherlands), it is hard to obtain the right taps and I don't like to experiment as this will further deteriorate the threads...
What type threads are used in Farmalls? Any standards that I can refer to? Probably a silly question for you, but I hope you will help me. Thanks, Hendrik
Hendrik
12-01-2003 23:21:05
 Re: Threads, what Type? in reply to Hendrik, 12-01-2003 02:10:06
You guys are very helpful; thank you all!
Now, together with my parts book, I'll be able to select the correct tap.
If there is anything I can do for you in the Metric field, feel free to ask :) You may even borrow my Metric wrenches ;)
Slowpoke
12-01-2003 23:01:21
I am surprised that no one has mentioned a thread gage. I'm sure you have available metric thread gages in the Netherlands; your hardware supplier should be able to get a US standard thread gage for you. Also known as a screw pitch gage. One with 28 leaves should be adequate.
Once you know the thread size, you can buy the correct taps or dies.
wdTom
12-01-2003 17:13:25
You have a lot of information on threads from the other guys. But what if you just want to order a few taps and be done with it. Ask on the Farmall board what the thread is for the holes in question, then jsut order that. For instance, What is the thread that holds the blank on? And the answer will come back 3/8-16. So you order a tap of that size. If you only need a few, it will be cheaper to just buy what you need. If you want a set, because you want a set, well and good buy a set.
D.L.
12-01-2003 12:21:01
Hi Hendrik, Looks as if these guys did a pretty thorough job of explaining the SAE system of threads. Just thought I'd point out a few references in case you want more information. For a complete explanation of ALL thread forms, check out Machinery's Handbook. This is an authoritative reference on ALL aspects of machining and metal-working processes. You might find used ones at www.ebay.com or do a Google search and you should be able to find Machinery's home page to buy a brand new one. Another useful source is ENCO... a supplier I use frequently. Contact at www.use-enco.com and ask for their 1000+ page catalog. They sell Machinery's Handbook for about half the price of buying it elsewhere. They can also supply you with taps/dies, etc. Finally, ENCO's parent company, MSC, is a good source for just about anything. Although their prices are a bit higher (I buy from ENCO whenever possible) MSC's catalog is more than 4000 pages... their selection is almost limitless. I've had very good service from both companies. Contact MSC at www.mscdirect.com Hope this helps!!!
D.L.
12-01-2003 12:43:37
 Re: Re: Threads, what Type? in reply to D.L., 12-01-2003 12:21:01
I just logged on to ENCO's website... it's a bit confusing. I was unable to locate Machinery's Handbook using their search engine... good thing I had my catalog handy to look up the stock number! Anyways, their part number for the book is 205-1043, currently available at $59.49... that's a pretty good deal... I paid over $100 for mine several years ago. If you need anything else, please let us know!!!
CNKS
12-01-2003 07:53:17
If you have a parts book, it lists the length, diameter and threads per inch on about every bolt on the tractor.
Fred OH
12-01-2003 07:53:10
Hendrick...here is a bit of useful information on american type threads. Usually the hex head of a bolt will be 1 1/2 times the bolt thread diameter.
Example; 1/2" diameter bolt X 1 1/2 = 3/4" which is the wrench size. The only one it doesn't work on in the fractional sizes is 1/4"...which the wrench size is 7/16". Fred OH
Hendrik de Bonte
12-01-2003 05:32:32
To SamH and Fawteen. Thank you both for your responses; they seem to complement each other pretty well. So I can expect the threads to be (U)NC or (U)NF. Do these threads have an angle of 60 degrees? I am asking this question because I've also heard of Whitworth thread which has a 55 degrees angle and is also measured by OD in inches and threads per inch.
Thanks again, Hendrik.
DaveCA
12-01-2003 06:08:25
 Re: Re: Threads, what Type? in reply to Hendrik de Bonte, 12-01-2003 05:32:32
Yes, it's 60 deg also, unlike whitworth. See link.
John Ne.
12-01-2003 13:15:50
 Re: Re: Re: Threads, what Type? in reply to DaveCA, 12-01-2003 06:08:25
Whitworth standard was primarily British. Do not believe any whitworth threads were done in the USA. John in Nebr.
SamH
12-01-2003 04:30:52
Hello Hendrik. I can give you a few of the basics, but you can find a lot more info than I can give here by typing metric/inch thread comparison or something like that. You can find charts, vendors, etc there. Google is good for this kind of search.
The Farmall threads are designated by the bolt/tap diameter in fractions of an inch and the number of threads per inch of length. For example, a 1/2 inch course thread bolt will be designated 1/2-13, meaning the diameter is 1/2 inch and there are 13 threads per inch. If you only have metric measuring instruments, that would be 12.7mm diameter and 1.95 pitch (distance from one thread to the next). See the conversion info below.
I don't know all the bolt sizes on your Farmall, but its a sure bet you will find some of the following - 1/4-20, 5/16-18, 3/8-16, 7/16-14, 1/2-13, 5/8-11, 3/4-10. Unfortunately, there is no direct metric substitute for these sizes, but in some cases, you might find something close enough to work.
The conversion factors are 25.4 mm = 1 inch and .03937 inch = 1 mm. To find the size tap you need, measure the bolt diameter and count the number of threads in one inch of length.
Hope this helps. If you don't find what you need, let us know. Good luck.
Fawteen
12-01-2003 02:29:01
There will be various sizes, but all of them will be SAE (Society of American Engineers (I think)) and either NF (National Fine) or NC (National Coarse) thread. Most will be NC. They will be in fractional inch sizes from 1/4 inch or so up to perhaps 1/2 inch on big things like wheel lugs. The size refers to the diameter of the bolt shank, NOT the bolt head or wrench size used to install or remove them.
A fairly standard set of taps and dies is available for around $50 US that would cover your needs. Don't know if Sears does international sales or not.
TimV
12-01-2003 13:36:15
 Re: Re: Threads, what Type? in reply to Fawteen, 12-01-2003 02:29:01
Fawteen: Society of Automotive Engineers, actually, or at least that's what my last dues statement reads.....
Fawteen
12-01-2003 15:48:00
 Re: Re: Re: Threads, what Type? in reply to TimV, 12-01-2003 13:36:15
Well, he77, 2 outta 3 ain't bad...":^)
TimV
12-01-2003 15:58:50
 Re: Re: Re: Re: Threads, what Type? in reply to Fawteen, 12-01-2003 15:48:00
No Problemo--if that's the only mistake you make today you're WAAAAYY ahead of me.....
Fawteen
12-01-2003 17:39:40
 Re: Re: Re: Re: Re: Threads, what Type? in reply to TimV, 12-01-2003 15:58:50
Hah. I should BE that lucky. If I only make one between getting out of bed and my first cup of coffee, I'm doin' good...
