Tool Talk Discussion Forum
Lincoln welder ac/dc to cut with
Jim
11-30-2003 03:49:58
Heres my dumb question can a guy use a stick welder to cut pipe angle iron ext.if he has the correct I guess cutting rod.a company down the road leases the two tanks for $ 110 a year plus $ 43 to refill the gas and 23 to refill the oxy plus I still would have to buy the cutting torch gauges lines ext for $ 169.00 which is the better route to take here.Thanks Jim
BillR
12-01-2003 00:04:10
 Re: Lincoln welder ac/dc to cut with in reply to Jim, 11-30-2003 03:49:58
Gee, I've asked that dumb question...that makes at least two of us! This started as a short answer but now looks like a laundry list.
What's best for you depends on what you're cutting and how much you're cutting. Half a dozen times I've used my stick welder to cut 12" heavy pipe in a pinch. I didn't have any cutting rods, and just used 6013 rods. It'll do it but it is slower than a torch and the cut isn't very clean. And watch your duty cycle if you're cutting a lot. If you need a clean edge you can dress it with an angle grinder.
For small stuff, less than 2 or 3" or so, I often use a 14" abrasive cutoff saw--$50 at Harbor Freight. For that matter, if you're just cutting very small stuff, say 1 or 2" now and then, use an angle grinder with an abrasive cut-off blade. It's fast and clean, cheap, and more accurate than a torch.
Stationary band saws are great too, but more limited. If you'll be cutting a lot of small stuff and need something portable, think of a porta-band saw. They're pricey, and overall have less utility than an oxy-acet rig, but they're wonderful. (One thought is that usually when you're cutting something you'll be sticking it back onto something else. The gas or stick welders will do that. Band saws no.)
For bigger stuff or if I'll be cutting a lot, I usually use oxy-propane. Sometimes oxy-acetylene if that's what is handy and I'm not cutting much. Oxy-fuel cuts a clean line after some practice. I bought my torches and tanks used here and there. They're less expensive if you're patient.
You can avoid buying the acetylene tank if you use propane, but it has other drawbacks--the tips are a bit more costly (well, $8 each via the web)and you should use T-type hose if you're running propane. You can braze steel with oxy-propane but not weld. Good luck.
Slowpoke
11-30-2003 22:17:05
Depends how much cutting you need to do. If it's a daily job of several hours cutting up scrap, use a torch with propane and oxygen. If it's cutting rod, tube, flat and angle for a project, get a $200 metal cutting band saw. It will make pretty good smooth square cuts compared to torching the pieces.
Dieselrider
11-30-2003 05:40:44
That sounds high for an annual lease. I paid three or four hundred for my set up but, thats buying the tanks and all. Thae fill ups aren't as high as you have either. I'd look around for someone else to buy from. There are other ways to cut with a welder but the setups there aren't cheap either. You can use an incorrect rod for the polarity and cut that way but it's not the best way.
Nebraska Cowman
11-30-2003 04:45:19
I run my torch on propane, still have to buy the oxy. The welder will cut iron but does a ragged job. One of the best investments I ever made 30 years ago was a power hacksaw.
