Hello Robert, In the days when these old electrodes were used on the production line, they were identified in such a way that allowed manufacturers to pick and choose electrodes bases on the application and the known composition of the metal. Part of the luxury of welding under the "Ideal" conditions created only on the production floor. Forget that when you work in the maintenance department. Here is a brief description of the code. "E" designates an arc welding electrode. The next two digits, in this case "70" designate a minimum tensile strength of 70,000 P.S.I. as welded. The following digit, in this case a "1" designates an all position electrode. The last digit, describes several things. It describes the power supply, type of covering, type of arc penetration and the presence of iron powder. ( Some of these electrodes used to be color coded.) In regard to the 7018, the polarity is designated to be DCRP or AC. The coating is of the low hydrogen variety. Lime coverings and titania and iron powder coverings are used to achieve this. The 7014 is designated DCRP, DCSP, and AC. In comparison of the two electrodes it is the last digit which sets them apart. In the realm of welding, when alloy steels are subjected to hydrogen in the molten state, a condition known as hydrogen embrittlement occurs. ( Not good if we're talking about the truck frame you just extended or the bridge beams you joined.) To overcome this, the low hydrogen coating creates a gaseous atmosphere around the arc and holds the atmosphere at bay. After about 30 minutes exposure to the atmosphere, the electrode coating has drawn enough moisture to require baking at 250�F to remove enough moisture to restore the low hydrogen effects of the coating. Unless this procedure is followed, the electrode becomes a miniature hydrogen and O2 factory. (A positive electrode in water separates the O2 and a negative electrode separates the hydrogen. This is one method used to commercially produce O2 and hydrogen.) In extreme cases, the gas being produced under the coating develops enough pressure to "blow" the coating off the wire during welding. This is why I cringe when I see people buy welding electrodes at auctions or when I see electrodes lying in an open tray for sale at the farm and home store. Things like this are what breathed life into companies like the one I work for. The differences between production conditions and maintenance conditions put them at opposite ends of the scale. Maintenance electrodes are designed for extended storage and less than ideal welding conditions. More often than not, you will have no control over contaminants, temperature of the metal, welding position or base metal composition. The skill or lack there of in regard to the weldor are also taken into consideration among other things. Most of my customers are not welding experts but are experts in other fields, such as, farming, machining, electrical, mechanical, engineering, etc. and in their day to day operations, they also weld. It is also beneficial to me in knowing these people when I need help outside of my field of expertise. Steve
