Tool Talk Discussion Forum
air compressor
hay
11-29-2003 03:28:06
i have an older model speedaire air compressor ( 20 gal tank 1 hp motor) about 20 years old. it is not used much, about twice a week. up until about a month ago everything was working fine, and then one morning when i switched on the motor, it started making a squeeling sound and the motor was actually slowing down by itself before it built up to normally shut off. the belt is new and snug and the compressor head has oil in the crankcase and after doing this "slowing down" several times, then it starts operating normal. any ideas about what is causing this? if i use it in the warmer afternoons everything works normal. just seems to be in the cool mornings. i have not got a clue as to why the motor is slowing down.
Roger
11-30-2003 11:00:14
 Re: air compressor in reply to hay, 11-29-2003 03:28:06
Check any capacitors while you're at it. Make sure the start switch inside the motor is operating properly.
SHANNON
11-29-2003 13:54:48
You have a problem with the motor bearings, lubricate or replace.If run like this too long it will cause the motor to burnout because slowing down will cause the start windings to activate trying to develop more power
hay
11-29-2003 14:52:01
 Re: Re: air compressor in reply to SHANNON, 11-29-2003 13:54:48
it may seem like a stupid question, but how do i lubricate the bearings? i don't see any lube points. does the motor have to be disassembled to lube them?
Mac
11-29-2003 18:03:00
 Re: Re: Re: air compressor in reply to hay, 11-29-2003 14:52:01
No oil holes? They are probably sealed ball bearings. Take the belt off and turn it by hand, does it coast freely? I dont think its the motor, maybe the unloader valve is hanging or bad. Seems you could remove the pipe that's connected to the head, see if it runs. If it squeals belts, dont think motor is a problem.
Vern-MI
11-29-2003 10:51:49
If the squeal is coming from the belt then the motor is still developing full torque and the problem has to be resistance of the compressor to rotation. That resistance can be caused by several things. First make sure that it is being shut off by the pressure switch at the correct tank pressure. If it is not being shut off at the correct pressure, 100 PSI, but instead shuting off at a higher pressure the resistance could be causing the motor slowdown and belt squeal. Next look at the check valve in the main line from the compressor to the tank and make sure it is opening and closing free and properly. Also check the intake filter to make sure it is free of excessive comtamination which would increase the intake vacuum and cause excessive torque at the pump shaft. Next thing to check are the main and rod bearings by taking the belt off and rotaing the compressor by hand to see if there is excessive resistance. If that doesn't solve it then it could be sticky valves in the compressor head but I doubt this is the problem. The only other thing I can think of would be some scoring developing on the cylinder walls from dirty intake air or improper lubrication. Good luck in finding the problem.
m t pockets
11-29-2003 08:29:47
My guess is the bearings in the motor need oiling.Might require disassembly.
Alvin n Ms.
11-29-2003 06:41:07
Most likely is the check unloader valve. It usualy is mounted at the tank end of the tube(pipe) that comes from the compressor. alvinnnms
