Tool Talk Discussion Forum
To Roger, The compressor guru. (or any one else th
Gene Davis (GA
11-28-2003 19:19:39
Fellow brought me a compressor unit the other day, no tank,etc or anything but the business end. It is a 2 cyl. single stage looks to be about 2"bores,and is put together entirely with socket head capscrews, and the flywheel has 3 main spokes that are cooling fans, and 3 half length ones that are fans also. No numbers, or markings I can see any where, how can I identify it? Is there any source of pictures or such to look at for ID'ing one? Thanks Gene
Roger
11-29-2003 18:27:06
 Re: To Roger, The compressor guru. (or any one els in reply to Gene Davis (GA.), 11-28-2003 19:19:39
Sounds like it might be an old Smith compressor. Is there a metal fram that bolts to the cylinder head that holds a felt pad in place for the air filter? i am guessing here, since Smith is the only small compressor I know of that used Allen bolts for fasteners. Usually, they had a plain 3 spoke flywheel, in my experience, though flywheels have a tendency to get broken.
Gene Davis (GA.)
11-29-2003 18:52:21
 Re: Re: To Roger, The compressor guru. (or any one in reply to Roger, 11-29-2003 18:27:06
Thanks Roger. yes it has a metal housing for the air intake filter, and it is definitly not a refrigeration type compressor. Is this brand of compressor in production now, where to get any parts if so? The flywheel appears to be original. Don't know if it needs anything or not, just curious as to what I had, Thanks to all again! Gene
Gene Davis (GA.)
11-29-2003 18:51:53
Thanks Roger. yes it has a metal housing for the air intake filter, and it is definitly not a refrigeration type compressor. Is this brand of compressor in production now, where to get any parts if so? The flywheel appears to be original. Don't know if it needs anything or not, just curious as to what I had, Thanks to all again1 Gene
Gene Davis (GA.)
11-29-2003 18:50:22
Thanks Roger. yes it has a metal housing for the air intake filter, and it is definitly not a refrigeration type compressor. Is this brand of compressor in productiom now, where to get any parts if so? The flywheel appears to be original. Don't know if it needs anything or not, just curious as to what i had, Thanks to all again1 Gene
Roger
11-30-2003 08:36:11
 Re: Re: Re: To Roger, The compressor guru. (or any in reply to Gene Davis (GA.), 11-29-2003 18:50:22
Does it look someting like this?
tick
11-28-2003 19:49:08
sounds like
something from a old commercial cooler
