Tool Talk Discussion Forum
Concrete Hammer
Trinity
11-28-2003 16:28:16
What kind of hammer would I need to put nails into concrete for flooring and my basement walls. I ould like something that lasts because I have ALOT of nails to put in. And about how much am I looking to spend?
buck
11-29-2003 09:18:00
 Re: Concrete Hammer in reply to Trinity, 11-28-2003 16:28:16
If you are able to have the extra build up on the floors and walls I would recommnd that you just lay in joist and a complete stud wall that does not require attachment to the existing concrete. This way you will be able to install a more complete moisture barrier over the concrete and not penetrate it with the nails/screws. I think you will find that per code that all wood touching concrete/masonry must be treated. For any nailing to concrete the 22 powered systems are the way to go and these systems can be found in the 20 to 30 dollar range. There are many flooring systems on the market that do not require nailing or glueing to the concrete floor so have a look. Good luck with your project.
Rick
11-29-2003 05:50:17
I would use a hammer drill and use redheads to hold base 2x6 in place then stud the wall from there.
Mac
11-29-2003 06:46:26
 Re: Re: Concrete Hammer in reply to Rick, 11-29-2003 05:50:17
I used a hammer drill and redheads and it worked just fine.
VaTom
11-29-2003 04:53:03
Here you go:
KURT
11-29-2003 04:25:04
I recommend using a .22 cartridge setup, you will need to buy a set of earplugs. BTW, I would also advise against using drywall on your basement walls unless you are absolutely sure that you will never have a water problem. I saw one basement that the guy used drywall and had a small water problem and one wall of drywall had to be replaced, use T-G wood boards or paneling. Have fun.....
Brian G. NY
11-29-2003 06:19:26
 Re: Re: Concrete Hammer in reply to KURT , 11-29-2003 04:25:04
A friend of mine (a retired Union Carpenter) told me he had to take a short course and be certified before he could legally use a Hilti gun. He wasn't sure but thought you had to have this certificate in order to purchase the "ammo" for it. This is in NY state; anybody know more about this?
VaTom
11-29-2003 12:32:38
 Re: Re: Re: Concrete Hammer in reply to Brian G. NY, 11-29-2003 06:19:26
Lowe's offers both loads and nails for concrete.
kraig WY She live in Wyo
11-29-2003 07:41:34
all you need is money
kyhayman
11-29-2003 06:44:16
Must be a New York thing. I got one at the corner harware store and buy the .22 blanks there too.
Butcher
11-28-2003 17:43:40
There are alot of ways to fasten wood to concrete. Alot of what you use dependes on the situation you have to deal with. If you are going to apply hard wood flooring to a concrete floor I would advise against trying it. The Pergo type stuff needs to float so as to expand and contract. If you really want to put the wood to the crete , here is a link. I would rent as the price is very high.
