Removing a head
cg
07-24-2000 05:03:06
i think i have to remove my head and replace the gaskets on a 9n. the head has a bunch of new paint around it. what do i do if the head will not budge, I've scored the paint downn to the old gasket? how do i free the head from the block wiothout hitting and cracking it?
what are valve seals? Roberts Farm sold me a gasket set that has them in the set. I jjust didn't get the head gasket alone. should i replace those inside the head too? i am obliged. How di I do all of this? cg
Head removal, the Wile E. Coyote way.....
08-13-2000 18:11:02
 Re: removing a head in reply to cg, 07-24-2000 05:03:06
My former boss used to regale me with his exploits as a neophyte mechanic working in Africa for a british contracting company in Nigeria. Often, they were far away from the parts and tools needed to do a job and had to improvise. Inevitibly, this lead to some rather unorthodox mechanical techniques, one of which involved removing the cylinder head from a Ford diesel by taking out all the cylinder head bolts and useing the 23:1 compression ratio to break it free. It worked wonderfully, but may not be a method you would choose to emulate!
Bob (KY)
07-26-2000 16:13:10
cg, GO the "N" Board on this forum BEFORE you proceed !!! There are some recent posts on this very thing. Also, there was discussion on having the head planed. DO read these posts. They may still be on the current pages, if not check the archives and look for posts within the last few weeks. The guys on the "N" Board are pretty sharp when it comes to these tractors.
Good Luck !
Bob (KY)
Steve U.S. Alloys
07-26-2000 15:39:08
Hello CG,
As a kid I went to auto mechanics school. I wanted to do that for a living until the kid in the bay next to me was killed one day. He didn't use jackstands. Fatal mistake. He was 17. There is no more helpless feeling in the world than to stand there and watch someone die knowing of nothing to do to help. I'm 45 now and I still get the willys if I'm under a vehicle and hear something creak or groan.
Anyway, I still remember lots of it but I'm afraid I am outdated badly when it comes to the new stuff.
I don't think you'll need to worry too much about hurting the head as long as you don't pry on an edge with a screw driver. Take your flat scraper and drive it under there gently as possible to break the old gasket loose. Try to get all the way around.
Valve seals go on the valve stem to keep oil from running down the stem and into the combustion area. As they age, they tend to get brittle and leak, allowing oil to get by and the engine will expell a cloud of smoke when first started after setting a while. If the seals get real bad, the engine will smoke every time vacuum is created. (rev'ving, coasting etc.)
That head should be surface planed to make it flat again and your valves and seats should be ground. It should also be cleaned and checked for cracks and other defects like valve guide wear.
If you don't know anything about these things, I would caution you against taking this on yourself. A catastrophic failure could end up costing you a motor.
My very unprofessional opinion,
Steve
DEAN SLAVICK
08-13-2000 14:08:25
 Re: Re: removing a head in reply to Steve U.S. Alloys, 07-26-2000 15:39:08
soak around the studs with liquid wrench. liquid,not aerosal.best stuff i found
