Tool Talk Discussion Forum
Pressure Washers
Gary in TX
11-27-2003 09:52:36
Hey guys,
I'm needing to get a new pressure washer to do cleaning on the hay equipment, tractors, knock old paint off the house, etc.. Anybody have any pros and cons on the different brands. I'm only interested in a gas powered unit of 5 to 6.5 hp and preferably a Briggs engine. I know Hondas are good but I like Briggs, just my preferance.
Thanks,
Gary
Steve B
11-28-2003 05:58:39
 Re: Pressure Washers in reply to Gary in TX , 11-27-2003 09:52:36
I bought a coleman 3500 4gpm w/ Subaru motor at the home depot for 399.00 last year. I use the to clean my dozers and heavy equipment. Sometimes the mud is so thick you cannot even see the tracks, just a big ball of dirt. My washer w/ the razor tip rips the dirt off with no problem. Be carefull when getting near hyro lines, you can cut them really easy.
also in maine
11-27-2003 18:52:02
karcher is big up here but from what i see anything less than 3-3500 psi is a joke for farm use
Dave Olson
11-27-2003 17:15:40
Hello Gary,
Have you considered a electric unit. Using 220v from your shop. If you wanted heat have the unit set-up with a Lp heater. For what you want to do a pump that delivers 2000 psi or so should do fine. Volume is what really cleans don't go less than 5 gpm, 8 would even be better.
Whatever setup you decide to get, it will last alot longer if it is belt drive rather than direct drive. The pump and heater coil will last longer if you run city water or treat the well water before runing thru the system.
If you have more questions send me a email.
Dave Olson - East-Central Illinois
EIL
11-27-2003 14:00:49
As far as pumps go, cat pumps are top of the line, comet pumps are cheap, AR and general pumps are good but less common.
KX
11-27-2003 13:06:31
Gary, I like the way you are thinking. I have a Honda 5hp on a Karcher 2400 psi and it has been nothing but trouble. I acquired a brand new 5hp CH with Briggs washer in a trade but sold it just before the Honda went to pieces on me. Boy I wish I had that to do over again.
Keith
TX
Steve-Maine
11-27-2003 10:03:54
I have a large Karcher which does hot and cold water and steam. Use it mainly to clean heavy equipment so I use the steam. The only problem is when you take it in for repairs. If I bought another it would be American Made. Just my thoughts
Alvin n Ms.
11-27-2003 18:27:11
 Re: Re: Pressure Washers in reply to Steve-Maine, 11-27-2003 10:03:54
A Sears Craftsman 2400 psi does a good job. I would like to have one more powerful for cleaning hvy. equip.
