Tool Talk Discussion Forum
Victor torch question
John A (TX)
11-26-2003 21:24:15
My current gas rig is an old Craftsman. Does fine on cutting but the smallest welding tip I have is a #3.
I'd like to use 0 or 00 tips to weld/braze thinner stuff so am shopping. Looks like Victor is the big name in gas rigs. I've seen one on eBay called a "Firepower Series 150" .. sells for around $110 +/-. Have also seen a Victor 315FC torch handle w/ CA2460 cutting attachment for around $130. This looks like the heavier duty rig.
Are either of these worth having for light to moderate duty around a farm shop? Other suggestions?
Thx ...
John A(TX)
T_Bone
11-28-2003 10:36:51
 Re: Victor torch question in reply to John A (TX), 11-26-2003 21:24:15
Hi John,
Theres nothing finner than a Victor 100 torch. Small body for great hand control and less hand fatique. A with a 3/16"x25ft hose works well for shop use. The torch is rated for 1-1/2" cutting or brazing 1/2" plate. Great quality and will last a very long time.
I pretty sure the Firepower 150 is a Victor 100 mixing body. You might want to confirm that.
Nothing wrong with other brands other than the large mxing body size is like using a club.
T_Bone
jokers
11-28-2003 06:39:52
Hi John A.
I wouldn`t rush to get rid of the old Craftsman torch. They used to be, may still be, made by Harris, which is a fine torch company. The Harris cutting torch barrels also have that neat feature where you can flip the cutting oxygen handle up so that you don`t indvertantly cut something that you are trying to heat with a cutting tip. I haven`t seen that feature on any other torch but possibly the Uni-Weld? Try any welding supplier who sells Lincoln equipment for tips.
Russ
john d
11-27-2003 07:04:32
We have a Victor in the shop at school that is a gem. When we needed something for lighter metal, I contacted my distributor and he sold us a small adapter that handles extremely small tips and simply fastens into the torch body like a regular tip.
MarkB
11-27-2003 04:27:10
For very light work, the Smith "Cavalier" is an excellent rig.
Doc
11-27-2003 00:41:01
I got the Victor 150 this fall off ebay. I am very happy with the set. I got it for light brazing, cutting and heating. I got a rosebud at Northern for heating. For the size tips you will be using it should be okay.
