Tool Talk Discussion Forum
Craftsman cordless drill
Revredneck
11-25-2003 06:40:29
Hey guys, I have a 16.8 volt Craftsman cordless drill that has a problem. It's in the Hi-Lo switch on the top of the unit. When I switch it to high speed, it makes a grinding noise and won't turn the chuck. When it's in Low range, it works fine. I guess it has a gear stripped or something like that. My question is: Can this be repaired, or would it cost so much that I should just buy another drill? I don't have any of the paper work for it, so I don't have a parts list or anything like that. Thanks in advance for your input. Good Luck and God Bless,
Tommy
dean
11-26-2003 05:58:28
 Re: Craftsman cordless drill in reply to Revredneck, 11-25-2003 06:40:29
ditto...i have 16.8, and it sometimes will make the grinding sound if the switch isn't fully engaged on the top...might be something internal you can fix?
Mac
11-25-2003 12:36:25
I got a couple different parts list for craftsman drills. DIY repair has surely changed a lot. All they show on parts is Bat, charger and chuck. A problem anymore everything is throwaway it seems.Sounds a bit like my 19.2 Volt, got a slide hi-lo 2 Sp switch on top. It may not be engaging, just a speculation, Take it apart. Nothing ventured nothing gained. As far as cost, a while back I got a 19.2 drill, circular trim saw and flashlite for 125 dolla's. Thinks these are made by ryobi now. Good luck on the parts. If there is a model number on the drill, go here and type in the number for a parts list.
http://www3.sears.com/
Fred OH
11-25-2003 06:48:07
Theres only about a half dozen screws to take out to find out what's wrong...just watch out for the brushes...they are spring loaded. I feel ornery today...so "the devil hates a coward"! (smile) Fred OH
