Hydraulic System Problems
HELP !
Rick
09-18-1998 00:16:46
Our church has an old 1973 White (make) dump truck. It had a broken line coming out of the hydraulic pump. I replaced the line, and now the bed will not go up. I AM NOT a mechanic, and know nothing whatsoever about hydraulic systems. It has dual rams. The bed used to go up before this problem. Do I need to prime the pump ? Do I need to bleed the rams, and if so how ? Any and ALL suggestions will most certainly be welcome. I would really appreciate any e-mail with suggestions, information on how hydraulic systems work or URL's to same, pictorial breakdowns on general hydraulic systems etc. Thanks in advance - Rick
Peter
09-18-1998 03:38:19
 Re: Hydraulic System Problems - HELP ! in reply to Rick, 09-18-1998 00:16:46
: Our church has an old 1973 White (make) dump truck. It had a broken line coming out of the hydraulic pump. I replaced the line, and now the bed will not go up. I AM NOT a mechanic, and know nothing whatsoever about hydraulic systems. It has dual rams. The bed used to go up before this problem. Do I need to prime the pump ? Do I need to bleed the rams, and if so how ? Any and ALL suggestions will most certainly be welcome. I would really appreciate any e-mail with suggestions, information on how hydraulic systems work or URL's to same, pictorial breakdowns on general hydraulic systems etc. Thanks in advance - Rick
DID you fill it with oil?
Rick
09-18-1998 11:38:11
 Re: Re: Hydraulic System Problems - HELP ! in reply to Peter, 09-18-1998 03:38:19
Sure did Peter, but still no workie. Sure wish I wasn't so dumb about these things. Thanks a lot.: : : Our church has an old 1973 White (make) dump truck. It had a broken line coming out of the hydraulic pump. I replaced the line, and now the bed will not go up. I AM NOT a mechanic, and know nothing whatsoever about hydraulic systems. It has dual rams. The bed used to go up before this problem. Do I need to prime the pump ? Do I need to bleed the rams, and if so how ? Any and ALL suggestions will most certainly be welcome. I would really appreciate any e-mail with suggestions, information on how hydraulic systems work or URL's to same, pictorial breakdowns on general hydraulic systems etc. Thanks in advance - Rick
: DID you fill it with oil?
Dumpster
09-18-1998 20:51:57
 Re: Re: Re: Hydraulic System Problems - HELP ! in reply to Rick, 09-18-1998 11:38:11
: Sure did Peter, but still no workie. Sure wish I wasn't so dumb about these things. Thanks a lot.: : : : Our church has an old 1973 White (make) dump truck. It had a broken line coming out of the hydraulic pump. I replaced the line, and now the bed will not go up. I AM NOT a mechanic, and know nothing whatsoever about hydraulic systems. It has dual rams. The bed used to go up before this problem. Do I need to prime the pump ? Do I need to bleed the rams, and if so how ? Any and ALL suggestions will most certainly be welcome. I would really appreciate any e-mail with suggestions, information on how hydraulic systems work or URL's to same, pictorial breakdowns on general hydraulic systems etc. Thanks in advance - Rick
: : DID you fill it with oil?
Turn the truck pto on
