Tool Talk Discussion Forum
Master space heater
Larry Entenman
11-22-2003 14:10:01
I have a Master kerosene heater model#B125.Spec#2590 s/n GKA1446 Iwould like the following. gap between plugs ,distance between end of points and tip of nozzle.distance of plugs off center to center of nozzle. thanks for any info on this .
Wayne
11-22-2003 21:13:29
 Re: Master space heater in reply to Larry Entenman, 11-22-2003 14:10:01
Hey Larry, look on the heater, if your heater is like most there will be a tag that says DESA on it along with a phone number. DESA makes alot of the heaters from Master, to Remington, to Dayton. They should be able to give you all the in fo you need. If that doesn't work try calling Graingers parts line and ask for tech help. I had to do that the other day about some compressor parts. I know there was another number they gave for the Tech help, but I don't have it here at home. The parts line number is 1-800-323-0620.
Good luck.
JDK
11-23-2003 10:22:43
 Re: Re: Master space heater in reply to Wayne, 11-22-2003 21:13:29
Also re:DESA,apparently there is a federal regulation regarding heating appliances that requires owner information be provided on req.I have found downloadable manuals for several DESA registered heaters,Gas and Kero,on line and download printable at no cost.
JDK..oops
11-23-2003 10:41:07
 Re: Re: Re: Master space heater in reply to JDK, 11-23-2003 10:22:43
Fergot
