Tool Talk Discussion Forum
Bits for drilling class 8 bolts
Alvin n Ms.
11-19-2003 09:04:26
What is the best bits, and procedure for drilling a broken 3/8 bolt? Is Noresman the very best? How to prevent ruining good bits? Thanks for your post. alvinnms
Try This
11-19-2003 10:02:21
 Re: Bits for drilling class 8 bolts in reply to Alvin n Ms., 11-19-2003 09:04:26
Can you get to the bolt heads with an angle grinder? If not you will want to go with a Cobalt bit. These are made with M-42 grade high speed steel. They are a better steel than the M-50 or M-7. But be careful to eliminate side torque if drilling with a hand held drill motor as cobalt bits are harder but also more brittle. Dont let them get too hot and dont over speed while drilling.
Alvin n Ms.
11-19-2003 10:59:04
 Re: Re: Bits for drilling class 8 bolts in reply to Try This, 11-19-2003 10:02:21
The bit breaking up when drilling a larger hole is a problem. Would I do better to try to drill out most of the broken bolt without first drilling a pilot hole? I can't get close enough to weld a washer and nut.
HD
11-19-2003 16:54:57
 Re: Re: Re: Bits for drilling class 8 bolts in reply to Alvin n Ms., 11-19-2003 10:59:04
If you have enough bolt to get vice grip or pipe wrench on it, try pecking on the broken stud with hammer. This works for me a great deal of the time.
T_Bone
11-19-2003 12:28:42
Hi alvin,
You can use a welding machiine to soften the bolt before drilling. Set the machine for about 100a, use DCEP, stick the rod to the head of the blot, wait until the bolt head is turning color, remove rod clamp (stinger), then remove the electrode, then drill when cool.
This softens the steel so it can be easy drilled with normal HSS bits.
You can also use a 12/6v battery with a piece of carbon (any welding supply) for the electrode. This works for smaller diameter bolts as you can sharpen the carbon to a fine point.
T_Bone
Alvin n Ms.
11-19-2003 18:06:45
 Re: Re: Re: Re: Bits for drilling class 8 bolts in reply to T_Bone, 11-19-2003 12:28:42
I am sure going to try this, Didn't know anything would soften a bolt. .Thanks for all the post.alvinnms
