Tool Talk Discussion Forum
Welding Cast Iron ....Again
Slowpoke
11-17-2003 09:57:24
I found that a 2-3lb disk from a weight lifting set would work as a ready made handwheel. I want to weld it to the end of a short, 1-1/2" black pipe so the pipe can be rotated. There's not much force to turn the handwheel, but it's probably low quality cast iron. Will a mig weld work using the common 70s-6 wire? I don't have a buzz box to use.
Kurt : Ky
11-19-2003 14:53:06
 Re: Welding Cast Iron ....Again in reply to Slowpoke, 11-17-2003 09:57:24
Sir go with what T_Bone and old say, mig will have poor results, have tried it.
Slowpoke
11-19-2003 23:31:28
 Re: Re: Welding Cast Iron ....Again in reply to Kurt : Ky, 11-19-2003 14:53:06
What are the results of mig welding steel to cast iron? Let's say we try to weld the end of a 6" long 1/2" solid steel rod to a 1/2" thick casting. Will it break apart with strong hand force, will it need several hammer blows or will it not 'stick' at all? Anyway, I solved the problem without welding or brazing by thru bolting a 3" washer to the 2-1/2lb cast iron weight. Then I welded the pipe to the washer. I used to bolt and screw every project together before I got the welder.
T_Bone
11-17-2003 14:44:50
Hi Slowpoke,
As "old" said, this may not be fun as they use some pretty bad castiron in those weights. Preheat would be best then try your Mig.
If that fails, then use oxy/acet with a borax/alcohol flux mix with a bronze, brass or silicon bronze filler rod. I personally would use this method vs your Mig.
Experiment is the key here.
T_Bone
old
11-17-2003 10:58:27
You could try it but it won't be very strong, if you have a torch you could braze it and that would be stronger.
You could take it to a welding shop and pay $10 to 20 to have them do it also.
Hope this helps
