Tool Talk Discussion Forum
M-W PowerKraft Arc Welder
mitch
11-16-2003 16:22:12
Does anyone know what the power req. are for this unit? It's 30 yrs old. 295 amp cap. is 50 amp braker O.K. or does it need to be more.
Ron
01-11-2004 12:50:28
 Re: M-W PowerKraft Arc Welder in reply to mitch, 11-16-2003 16:22:12
Does anyone know if parts can be gotten for these machines? How old is this thing anyway?
John K
11-17-2003 06:56:11
It depends what current you will be welding at. The highest current will dictate the breaker size. Most people weld in the mid range meaning higher duty cycle. Did some testing years ago, found that 30 amp breaker would hold unless the welder was pushed.
Big Rick
11-16-2003 16:34:38
Yes a 50 amp braker is fine.
Slowpoke
11-17-2003 00:20:14
 Re: Re: M-W PowerKraft Arc Welder in reply to Big Rick, 11-16-2003 16:34:38
I have the same 1973? M-W welder in the original box, never removed, never used, but... I thought it called for a 60 amp breaker. 25 to 295 amps, ACDC.
Some day I'll have to try stick welding. I use a 40 amp breaker on a 240 amp mig, welded 5/8" with it, no problem.
JoeA
11-19-2003 18:55:01
 Re: Re: Re: M-W PowerKraft Arc Welder in reply to Slowpoke, 11-17-2003 00:20:14
the configuration on the plug of your welder should determine breaker size...and breaker size will determine conductor size of the circuit
Slowpoke
11-19-2003 22:42:16
 Re: Re: Re: Re: M-W PowerKraft Arc Welder in reply to JoeA, 11-19-2003 18:55:01
Good thought... When I got the arc welder, I didn't pay much attention to the plug. I think it was in the instructions that I saw the 60 amp breaker requirement. I'll have to recheck it.
As for the mig welder, it's 240 amps and calls for a minimum circuit breaker of 40 amps. It also has an internal cb. I had to supply my own plug.
