Tool Talk Discussion Forum
641 Ford Hydraulic Lift
Davis
11-13-2003 21:04:07
The lift will pick up a load. The arms raise when there is no load. The tractor has been sitting up and I am attempting to restore it. Where should I start. Everything else seems to be fine. it runs pretty good, the PTO works, etc.
hay
11-15-2003 03:10:38
 Re: 641 Ford Hydraulic Lift in reply to Davis, 11-13-2003 21:04:07
wash out like alvin says, BUT, do NOT use diesel. use the ford 134 or equal hyd oil to flush out. that way there can be no foreign fluid contamination. diesel or anything else can never be gotten complety out, so why take a chance on messing up a hydraulic system? over 70% of hydraulic failures are due to contaminated fluid, such as water, wrong type oils, diesel and dirt.
Alvin n Ms.
11-14-2003 07:25:59
I would start by draining all the oil, trans, hyd, diff, then stick a finger in the hole to feel around for metal ect. If the oil is a milky looking color it has been contaminated with water. Then flush it all out with lots of diesel fuel. If you find more than a very small amount of metal, start tearing it down. A wash out will cure lots of hyd problems. These tractors take in water at the big spring behind the seat and at the gear shift.
