Tool Talk Discussion Forum
Using a portable generator on a 220 welder
Jim
11-13-2003 15:26:09
I have a 5.5kW generator and was considering buying a lincoln ac/dc cracker box welder and direct wiring it to the generator. Would this work? I would mainly be welding pipe for fence and corrals.
Ray,IN
11-14-2003 14:51:42
 Re: Using a portable generator on a 220 welder in reply to Jim, 11-13-2003 15:26:09
For little more than the cost of a new 5.5kw genset you can buy a used Lincoln 225 DC Lincwelder that will do your task much better and easier; and you may run 120vac lighting from the built in 3kw genset if you wish to weld at night by locking the engine RPM. Visit rentall stores and price used gas welders.
Bishop
11-14-2003 06:47:39
I tried welding with my 220V Lincoln-AC225, with my 6000W 10hp generator, but the results were poor.
Check out the gas powered welder/generators. At SAMSCLUB you can get a great gas powered welder/generator for around $900. I have rented one and they work great.
ray
11-14-2003 07:02:26
 Re: Re: Using a portable generator on a 220 welder in reply to Bishop, 11-14-2003 06:47:39
I run my thunderbolt xl on a 5.5k generator on occassion. 1/8 rod no problems yet. I used that generator just because I had it and it was easier to bring the welder generator to the problem. Wish list would includes a 12-15k 3phase generator.
T_Bone
11-13-2003 21:25:34
Hi Jim,
I ran my Lincoln AC and 115v wire feeder on my copper wound 4kw Koler for about 8hrs without any problems. I only used 1/8" rod. Of course the wire machine had no problems at 115v.
The larger the electrode diameter the more amps from the welding machine thus more amps from the genset is required.
I would not push any where close to the limit on the welding machine as it can't be good for longivity.
T_Bone
KEG
11-13-2003 18:22:24
I have a 5.5 Kw generator and a Lincoln AC225 welder. I used it once on the generator and it worked fine. But I don't plan to use this setup very often. Just when I need a repair out in the field.
KEG
max
11-13-2003 18:06:45
My lincoln welds real good on an 8kw genenator.
TimV
11-13-2003 17:43:13
Jim: I don't know if you'll be happy with this setup--neither Lincoln nor Miller recommends running a welder from a small (and 5500 watt is considered small) generator. The electronics on the welders are not efficient enough to work properly on these gensets--you'll get substandard performance, even at low amp settings. I had the same idea, but was talked out of it by a couple of guys I know who were very disappointed with similar setups. Lincoln recommends no less than a 15,000 watt generator be used on their standard AC225 "tombstone".
Robert in W. Mi
11-13-2003 16:35:52
Why direct wire it?? Buy a genset that has a full power 220v outlet, and just plug the wender in! At least then the genset can be used for something else some time!
Personally, i'd spend the $$ to get a really good genset, and then it will last a long long time!! (read Honda)
My personal choise is, a pto powered genset so i can run it with my small diesel tractor. It's big enough so i can put some lights up, run the welder and a side grinder or even a small heater if i want to. And, all at the same time!
I like my gen set and welder much better than the gas powered welders i've owner in the past. The secret is, DON'T BUY A CHEAP GENSET!!!
Robert
