Sediment bowl gaskets?
Dean E. Min
07-16-2000 18:02:50
Does anyone know where a person could get a set of misc. sediment bowl gaskets?Without having to go to a specific dealer to get the same brand as the tractor? Thank you for any info! Dean
Bob (KY)
07-26-2000 16:17:37
 Re: Sediment bowl gaskets? in reply to Dean E. Minn, 07-16-2000 18:02:50
Try Tractor Supply Company or a similiar farm supply store.
hitchpin
07-19-2000 18:52:22
make one out of an old inner tube they work fine
hitchpin
07-19-2000 18:51:25
ltf in nc
07-19-2000 07:11:04
Use an O ring. You will have to experiment with the diameter of the material and you can cut and glue with super glue to get the correct size of the O ring itself. Just be careful to get the ends aligned. Works a lot better than a gasket in eliminating leaks!
CA in NJ
07-17-2000 10:23:42
Try NAPA. They should have gaskets, bowls, and complete assemblies.
