Tool Talk Discussion Forum
Stihl 036 chainsaw
Ronald Poust
11-11-2003 10:59:47
I am getting no spark. The saw was running good. Refilled the gas tank and it started right up, then it started to sputter, then it stopped. Tried to start it again and it would not start. Let it sit for 1/2 hour then got it started , white smoke was comming out of it, then it cleared up. Then it stopped and can not get it started again. It seems there is no spark. Thanks, Ron
jim
11-14-2003 16:36:59
 Re: Stihl 036 chainsaw in reply to Ronald Poust, 11-11-2003 10:59:47
Spark plug is a common 2 cycle problem, but DO NOT USE any plug in it but a Bosch or NGK, with Champion, you are asking for trouble
Ron Poust
11-14-2003 20:38:21
 Re: Re: Stihl 036 chainsaw in reply to jim, 11-14-2003 16:36:59
Thanks for all your help. It turned out to be a wire that was rubbed down bare, and shorted the chain saw out. Thanks again Ron
Van
11-13-2003 04:39:20
Check the plug, then check the ignition module, they get intermittant when they fail sometimes.
Mac
11-11-2003 14:58:32
Try a new plug also, they have a habit of just quitting when you least expect it.
treeboy
11-11-2003 13:19:13
was the saw outside where water could get to the airfilter?? it sounds like your plug is wet or "cobwebed",, take your air filter off also clean plug & see if it will start... check for spark before putting plug back in,,your gas might have gotten water in it also, pour a gas sample in a clear glass container,meaning turn your can upsidedown when pouring so ya get the water if its in there
