Tool Talk Discussion Forum
Stihl 041AV Chainsaw Unusual Wear Question
John in MI
11-11-2003 09:17:09
I've got an old Stihl 041AV and have noticed that the outer ring of the clutch is rubbing the cover piece that clamps the bar to the saw. It has worn a noticeable groove into the cover, and seems to add drag to the chain whenever the nuts are torqued down. I've got another 041AV of similar vintage that does not appear to have any contact in this area. Does anyone know what might be causing this? Thanks,
John
Van
11-17-2003 10:04:11
 Re: Stihl 041AV Chainsaw Unusual Wear Question in reply to John in MI, 11-11-2003 09:17:09
Also check your crank shaft end play, if it is too much it will rub and its time for a overhaul of the crank bearings. If bad and you keep running it - - - KABOOM, its over
treeboy
11-11-2003 13:27:25
the 041's had a small tin like spacer on both sides of the bar where the two bolts hold it to the saw, they kind of direct the chain into the clutch area & keep the bar oil on the chain. If your missing the outsideone or both the cover will sit that much closer to the clutch.. Also are you running a stihl bar or a replacement that might be a little thinner than the orginal bar. The third & most expensive: is yoour clutch worn to the point that it wobbles or the interbearing shot...ps 041's where very good saws in there day
John in MI
11-11-2003 14:59:42
 Re: Re: Stihl 041AV Chainsaw Unusual Wear Question in reply to treeboy, 11-11-2003 13:27:25
Thanks for the tips. The tin guides are in place, and there doesn't seem to be much play in the clutch/bearing, but I do have a replacement bar on it. It's a Stihl, but I will measure the thickness and compare with the original bar.
-John
