Tool Talk Discussion Forum
Another Quincy Question for Roger?(please)
Trucks
11-10-2003 15:13:13
Hey Roger,
You are one popular dude. I was just wondering about a few things first: My 325 has that lvd valve on it like I told you about I found alot of rust on the spring and ball I cleaned it off, and I works well now, but I'm not sure what the purpose of that adjustable knob is all about? one cat told me that I could disconnect it and just use the regular Hyd. unloader above the oilfilter? any thoughts? and last I am going to put a head gasket on my dad's 230, and was considering putting new rings in it and honing it out, and replacing the valve discs, but the prices are pretty high on the rings and they only come with a whole kit. I was wondering if I could use rings that would fit from a local speed shop.They can get various sizes of rings and buy them seperately.your thoughts? email me directly at [email protected] or here if you don't mind, Thank you so much for all of your good advice! You are good on these old Quincys and I appreciate all of your help.
Trucks
Roger
11-10-2003 19:11:35
 Re: Another Quincy Question for Roger?(please) in reply to Trucks, 11-10-2003 15:13:13
Some compressors come equipped to run either off the pressure switch, or off a pneumatic head unloader. Sometimes, as with Curtis, there is a valve that lets you choose to run off the pressure switch, or off the unloader. When it is running off the PS, it will come up to pressure and cut out. If it is running off the unloader, it will come up to pressure, unload, but keep running. Running like this is more economical if the number of motor stops and starts per hour starts to get excessive (i.e. you are running near the maximum capacity of the compressor (common when sandblasting)). Also, the pneumatic unloader can provide a safety backup if the PS ever fails to open. Instead of pressure building up to the pop-off setting of the safety valve, the unloaders will kick in and unload the head. Of course, this only works if they are set to a higher pressure than the PS, otherwise, they will unload the compressor first. Incidentally, the PS will also act as a safety backup if the unloaders fail as well, as pressure will rise and cause the switch to cut out and stop the machine. So, the unloader valve is basically a way to provide dual mode running: stop start for the PS, unloaded running with the unloader valve. BTW, there should always be a safety relief valve in every compressor tank, just in case the compressor does not shut off for any reason. There should also be a 60-70 psi safety valve in the cylinder head of your Quincy.
If you are using your Quincy in strictly stop-start mode, you can ditch the unloader valve, and run a line directly from your tank, through the hydraulic unloader valve, to the head unloader towers. You will lose the dual-mode function however.
I have cross-referenced rings from a Hastings piston ring catalog for some obsolete compressors once in awhile, so it can be done. For the 230 though, I would head to a local compressor repair shop and ask them to order up some ICC parts. They are (usually) not expensive and work very well.
Trucks
11-10-2003 20:06:35
 Re: Re: Another Quincy Question for Roger?(please) in reply to Roger, 11-10-2003 19:11:35
Hey Roger, Thank you very much for all of your help!I appreciate your knowledge so very much.I was in favor of ditching the valve on my 325 cause I will probably never use it in that mode.Tonight I disconnected the LVD valve and did what you said, it works perfectly, before when it kicked on it took about 12to14seconds for the unloaders to kick out even though it was up to oil PSI, but now the unloaders kick out in about 3seconds.Thanks for all of your help, by the way where do you work? Or are you just a aircompressor junkie? Thanks again Roger!!
Trucks
GOD bless you!
