Tool Talk Discussion Forum
Who makes the best hand hacksaw
T.J.-N.J.
11-08-2003 17:02:00
Hi Guys, I finally broke my grand dad's old Govt. surplus hack saw. Is there a decent one available for 10 to 15 bucks. I want one where your hand is inside and enclosed not a pistol grip one, I still have a scar from one of that kind, when the blade snapped and my fingers punched into the piece of threaded rod I was cutting. Thanks for any suggestions T.J.
JEFF PK
11-09-2003 20:34:46
 Re: Who makes the best hand hacksaw in reply to T.J.-N.J., 11-08-2003 17:02:00
Good NEW hacksaws are hard to find. SO, buy the best one you CAN find. Try Garage and Estate sales or a machinst tool catalog. I have three solid frame hacksaws and never lend them out. They were made back at the height of the hand tool era and I have never found a comparable quality tool.
Jim in UK
11-09-2003 15:38:05
I am by far not the "expert" to comment on hack saws. Although, I also have gone and bought (about ten years ago) the Sears Craftsman hack saw because of the time and convienence. I would suggest either a Snap-On or Mac Tools hack saw. The ones that I have used with thier brand name on them have always been the best. Due to almost cutting the middle finger off on my right hand, may I suggest that you stay away from the Great Neck brand. In the early 80's I was working in a garage and we had a race car that we ran on the local dirt track. We were have trouble with the throttle linkage to the carb. It was decided that we would be best off to make this adjustable by putting a length of starter bolt into the linkage. I was using another guys hack saw and the blade kept getting twisted no matter what was done. Knowing better, I put my hand on top of the frame and kept the blade straight. This worked well until the blade broke and my hand came down on the cut bolt. If it wasn't for the bone, my finger would have been cut off. Please don't repeat this practice with using a hack saw and spend the couple extra dollars for a good one. Trust me, this was an accident, but I also know of others that were using a hack saw correctly and have had same results as I did with this cheapo.
Jim
greenbeanman
11-09-2003 12:32:30
My hacksaw is an okay one, probably 25-30 years old. It is P&C brand, which is probably some elcheapo. I don't use one a great deal, moreso use my bandsaw type one.
One feature that mine has that I do like is the tubular frame. You can store blades of different tooth count in it. It also adjusts to hold two different lengths of blades.
Alas I've lost the front blade holder so this is timely as I am having to replace mine also.
To help saw straight, keep the blade really tight.
John Garner
11-09-2003 12:24:10
TJ --
From what I've seen, there's not enough difference in the performance of any of the major-brand (Stanley, Buck Brothers, Starrett, Lennox, Sandvik, and so on) "high tension" hacksaws to make one model THE ONE and the others also-rans.
Having said that, I do prefer the "over center lever" tensioner to the "screw-clamped lever".
John
Pete
11-09-2003 06:53:27
By far in my opinion Stanley composit or aluminum hacksaw is the best design .Ergonometric correct and blades dont stretch nearly as bad as others>
Pete
John K
11-08-2003 19:41:37
(Greenlee) (Klien) make good ones, bought a copy of one of the above for 1/10 the price, can't tell the differance.
Jimmy King
11-09-2003 05:57:20
 Re: Re: Who makes the best hand hacksaw in reply to John K, 11-08-2003 19:41:37
Still use the one my Dad had when I was a little Boy don't know when he got it. Oh I am 62. P.S. I never could saw straight with hack saw or hand saw, don't expect I will learn to now.
JF
11-08-2003 21:16:16
A klien is just like Craftsman on warranty, but Klien does last.Where Craftsman you have to keep taking it back to get it replaced.I have never taken a Klien back in 10 yrs for anything.
wdtom
11-08-2003 18:37:55
Brand, I don't know but the type I have and like has the small rod on top that tightens the blade with a round nut above the handle. Works a rocker arm on the far end of the frame. Have had one for 25 years, and another for about 10, haven't seen more for less money.
Scott Green
11-08-2003 18:06:57
Pay a little more and buy a LENEX brand. There are some other good brands which look like the LENEX , but I can't think of the brand names at the present. If I think of it , I'll look in my truck tomorrow.
