Tool Talk Discussion Forum
Shop Crane Hoist any advice?
Richard
11-06-2003 18:29:44
I want to build a cantilevered I-beam crane with a trolley & chain hoist. My idea is to use a 5" well casing 15' long. Weld a large heavy plate to the bottom for bolting to the floor. Then slide a 6" well casing about 2' long over the 5" casing with a collar stop to hold it at 12' height above floor.This would be after welding the 8" I-beam to it. Then run a guy rod with a turnbuckle from the top of the 5" pipe out to the end of the I-beam. Hang the trolley with a stop at the end of the I-beam. The main pipe would also be anchored to the wall. Also would tap a zerk fitting in the swivel pipe & pump it full of grease. How long do I dare make the I-beam. Would like to go 16'. How's that sound?
Fred OH
11-10-2003 07:14:33
 Re: Shop Crane Hoist any advice? in reply to Richard, 11-06-2003 18:29:44
From what I've seen of well casing pipe...I was across the road one day watching a well driller apply his trade and he hit water at about 15/20 feet. He said "I'll fix that" and he drove in a casing...then he took a 15/18" crescent type wrench and bent a flare in the top of the casing and set another one in and welded them together. From what I seen there...if all casing is the same in wall thickness (roughly)...you better look for something more substantial.
I built one with 5" standard pipe and snagged something heavy coming off of a trailer and bent one of them...should have been more like 8"...maybe I'll put guys on this one for more stability ...rather than re-engineer. Go big is the answer. Fred OH
JMS/MN
11-07-2003 12:53:38
Sounds weak- you want a 16 foot beam on a shorter single support? Five inch pipe sounds too weak, along with the bolted floor plate. I have a 19 foot beam (7 wide,12 inch web) supported by an 8 inch pipe, cemented 3 feet in the floor, with a pivot at the top, like you describe, but the other end is supported by an inverted T made of 8 inch pipe and 6x8 beam on wheels. Has a 2 ton hoist on it, just unloaded an 18inch x 8 foot bed engine lathe, and a large milling machine. Cantilevered design needs a lot more heft, like the others said regarding twist, etc.
KeithF
11-07-2003 08:22:31
I used to design lifting fixtures at an industrial site. Designing a jib crane to handle a heavy load is not something to take likely or to cobble together. Catastrophic failure can occur quickly and virtually without warniing if the load swings. The "A-frame" type gantry crane is much easier and safer for someone to shop build. A jib crane requires a "massive" floor mount to anchor the large bending moment the load imparts to the base. A safer alternative is to buy a jib crane that is commercially available. For example, in a catalog I have a 12' high model with a 10' boom capable of handling 2000 lbs. costs $1272. It has a 16" square mounting plate. The concrete pad under the base would probably be specified in the crane literature and I assure you it most likely won't be a 3" thick garage floor. Be safe you can always investigate further by going to a manufacturer like North American Industries (www.naicranes.com)and asking for information. Good luck.
IndianaDan
11-07-2003 07:01:45
Hi, I use one at work similar to what you have in mind. 2ton air hoist,14ft beam,no rod on top. The vertical pipe is about 30" in dia. w/a 6'round base and is anchored to a concrete block 8'x8'x8'. The beam is hooked to a carriage that hangs on top of the pole and extends down five feet and rides around the pole. Made by P&H.
rhudson
11-07-2003 06:34:29
Hi Richard,
I haven't run the numbers, but a gut feeling is that the pipe will barely support the weigh of the 16 ft rail and trolley. you will most certainly need larger dia. tubing. need to be of thicker wall than schedule 40 pipe, which will rip and peel down if you put too much stress on it. we had one in our shop using a purchased thrust bearing. you might consider using a front spindle bearing from a heavy duty truck for both thrust and radial loading. i have a catalogue of lifting equipment around here somewhere. i'll try to find for you. jib cranes are nice, but are highly stressed. for most of us a rolling grantry crane (swing set, A frame thing) is a cheaper, safer way to go. i have one for outside use that uses truckwheels and tires with steel feet just above ground level. if you need a realy sturdy footing, i let the air out of the tires to set the feet on the ground. otherwise the tires do fine. the rail is suspended under the legs so that the trolley can go outside the legs to off-load things. i also have two trollies so that i can use both to position assemblies.
Dan in Ore
11-07-2003 06:24:18
I would explore the possibility of a "bridge" crane instead of a "jib" crane. With the bridge you have the same amount of stress on the structure regardless of the position of the trolley. I built a small jib crane over the lathe so I could handle the chucks and large items, but for the main part of the shop I would opt for a bridge crane for the heavy lifting. If you could span the entire shop with a bridge, I believe it would be much easier to use as well as safer.
Just my $0.02 worth.
Always safety first.
Dan
Chris
11-07-2003 05:04:25
I don't think the 5" pipe is near heavy enough at that height. Even if it didn't fail it would flex and cause your load to bounce around out of control and your beam would tend to run down hill making it impossible to hold a heavy load in place without it wanting to roll away. I would seriously talk to an engineer or figure out some calculations before you spend alot of time and money on this. Remember leverage is a huge factor here- 500 LBS on the end of your beam could translate to several tons being supported at the post. The most important thing here is safety. When overhead cranes fail it can be real ugly to you and your wallet.
VaTom
11-07-2003 03:40:18
Richard, we had a discussion on this. ShepFl had a great plan. Never did see the installed picture, but here's the prototype:
ShepFL - VaTom yer quick
11-07-2003 11:23:47
 Re: Re: Shop Crane Hoist any advice? in reply to VaTom, 11-07-2003 03:40:18
I was trying to locate that same pic!!
Grins from here in FLA!!
ps - I gave up on the shop crane idea and built the Mrs. her house. I now have more debt so my shop crane will be an A-Frame with chain hoist.
VaTom
11-07-2003 17:16:07
 Re: Re: Re: Shop Crane Hoist any advice? in reply to ShepFL - VaTom yer quick, 11-07-2003 11:23:47
Sorry to hear that. I thought it was a good plan. Sure was a great picture!
old
11-06-2003 19:04:43
My shop has a mobile home frame I beam in it that I have a 3 ton hoist on its about 18' long under it down to the ground is a 2X2 iron tube on each end and I can pick up a 1/2 ton chev high enough to take all four tires off. Hope this helps a little
Jailkeeper
11-06-2003 18:47:44
I don't think your 5" pipe would last be standing upright for very long. I would suggest a much larger pipe - maybe 10 or 12" diameter for an upright crane. I'm no engineer, so I don't know what kind of loads you'd be capable of, but it would be easier to overbuild the first time rather than have to rebuild the original.
A guy I worked for made one like you described. I believe it was a 20" pipe and had a 10' I-beam. The shop caught on fire and burnt completely down. The I-beam got so hot it warped and the trolley wouldn't slide anymore. He built a new shop but never fixed the crane. Good luck.
