Tool Talk Discussion Forum
HELP! Wire welder backlashed
Scott
11-06-2003 14:25:11
Transported my 110v Hobart wire welder to the farm last weekend, and the darn thing stopped feeding wire. Being curious, I opened the side only to find my spool of wire backlashed like a cheap fishing real.
Have you ever re-wound a spool? I've got probably 15 or 20 wraps loose, and I really don't want to cut that much off, but I can't kink it at all. Any ideas would be helpfull.
Thanks
wh
11-06-2003 17:27:37
 Re: HELP! Wire welder backlashed in reply to Scott, 11-06-2003 14:25:11
not to make a pun - but - go ahead and cut your losses. pull off the loose wire and cut it you will be ahead in the long run of things. wade
Rewind if you can
11-06-2003 15:25:18
It sounds like the nut holding tension on the spool was not tight enough. Slide the spool off of its spindle and carefully unroll it untill all the loose wraps are off. Then carefully rewind it. If you run into any kinks cut the wire (and your losses) pull the bad section out, rethread and return to welding.
