Old kellogg air compressor
desertrat
07-14-2000 16:02:34
I can't understand how this old kellogg model air compressor gets its fresh air. I'm trying to rebuild it, but both cylinders have lines going to tank, and no intake.Does it work like a two stroke engine, with ports?Where is air intake at?
Before i dissasemble it,i would like to understand it. Please help, someone.
Troy
10-27-2001 16:26:03
 Re: old kellogg air compressor in reply to desertrat, 07-14-2000 16:02:34
Hi, I have american kellogg air compressor model 332. I read in one of your follow ups not to use motor oil in them. Please tell the right the oil to use in these compressor's. Also where can I find any drawings of this compressor and parts list.
thank you for time
Roger Prosper
07-20-2000 20:50:52
Hi:
All the Kelloggs I have worked on have been pretty straight forward machines. Maybe someone has plumbed it in wrong or has a pipe screwed into the intake for a remote air filter. It may be a two stage machine which could be confusing you somewhat. The first (larger) cylinder, takes in atmospheric air and pumps it through an interstage tube (the finned one behined the flywheel) into the second (smaller) cylinder. Most Kelloggs have their air filters on top of the head or at the rear opposite end to the flywheel. Which model is it? (352, 452, 462, 123, 335, 340 ??) If it has a tag that says American Brake Shoe Company, it is very old. They have been owned by CompAir for many years. Be careful when dissassembling or reassembling Kelloggs. For some reason, the cast iron they are built with strips its threads like it's made out of cheese. This is especially critical if the back of the crankcase is split so the crank and rods can be inserted through the back as an assembled unit (most smaller Kelloggs are like this). They are very prone to breaking here and are scrap if they are, unless you can weld it up and re-tap it (not cheap). They have a centrally mounted oiler ring on the crankshaft (like a real DeVilbiss) so be very careful when removing it so you dont bend it. It has to be gently twisted sideways and lifted out of its retainer which is cast into the bottom of the crankcase. The crankshaft rides on tapered roller bearings and must be shimmed for proper end play when being assembled. Many, if not all Kelloggs use needle bearings on the high pressure wrist pin and so avoid the common problem of worn bushings, pins and pistons common to many brands of compressors. Make sure the little brass blow down valve on the back of the case is working if it has one. Make sure you put in a 60 psi safety valve in the interstage. This will blow if you have valve trouble. If the valves clamp into the head with a retainer, make sure you torque the bolts down evenly so you don't break the retainers.
Kelloggs are long lived, excellent, durable machines. Don't use motor oil in it. You can probably buy a rebuild kit for it from any compressor shop, who will probably have to order it in from ICC out of New York (aftermarket parts).
Joseph Enochs
04-22-2004 19:49:14
 Re: Re: old kellogg air compressor in reply to Roger Prosper, 07-20-2000 20:50:52
Need bleeder check valve with .25 inch female pipe fittings on both ends.
Peter
02-16-2003 11:00:26
Hi I have a kellogg air compressor that says it is made from american brake show company. I was wondering how can i know the horsepower and the cfm unit. It is pretty big unit and is horizotal on a 80 gal tank. Is thsi compressor worth keeping or is it better to sell it. thanx Pete
Kris
03-29-2001 19:14:40
Roger
I have a model 321 TVA Kellog American compressor made in '68 that I was thinking of rebuilding, can you give me any tips or things i should be aware of before i take on this project?? Any idea what it will cost?
Thank for any info you may have.
Sleepy
