Basic Welding Help
Doug Barton
07-14-2000 07:34:33
Building a pipe fence using 2 3/8 inch pipe.
How much heat will I need for this weld and which
electrode? I am looking at the Miller Bobcat and
Bluestar for the job. Any comments on these products and if they will do the job will be
appreciated. Thank you.
mom
06-16-2002 18:28:35
 Re: Basic Welding Help in reply to Doug Barton, 07-14-2000 07:34:33
I have a daughter who is incarcerated and is learning to weld. I know nothing on the subject & am trying to find some books to send her. I'm looking for the very basics. Can you help me?
I would appreciate it. Thank you
perry roden
05-11-2002 20:41:09
need information on basic welding. how to get started.
mike happeny
03-12-2001 14:21:49
I went to the V.I.C.A. Regional competition and they had me mig weld a T-fillet in the vertical up position. it didnt work, it just formed alot of running beads. how do i do it. could you help me.
Steve U.S. Alloys
07-15-2000 06:22:48
Hi Doug,
I posted a response to your question on the other forum. Just happened to check it first.
Steve
FRED
07-14-2000 18:32:48
Use 7018 DC + 130 AMP 2-3 passes per joint. FRED
Bayou Dave
07-14-2000 14:52:22
Is that old drill stem? Some of that can be radio active, and some of will magnetized, and some will be brittle. Good luck with it. Dave
Halsey Green
07-14-2000 10:16:09
I have a question? - Is the pipe you will be welding galvanized? If so be careful, the fumes from galvanized pipe are toxic if inhaled. Have a fan to blow the fumes away from you and be carefull of not getting them under your helmet.
Tyler(WA)
07-14-2000 08:45:34
I'm sure your welder is up to the task. I'd talk to your welding supply store and ask them for some help. My shop is run by some highly experienced welders who really know their trade. They've helped me several times and actually enjoy having someone ask questions and respect their depth of knowledge.
