Tool Talk Discussion Forum
Hobart portable troubles
Fred OH
11-03-2003 12:38:47
My old Hobart finally got tired...it's the one with the two cylinder Wisconsin engine with 12 volt electric start. I have the manual on the engine, but not the welding generator. I can't even find a serial number or model number on it...so, anyhow, it's probably a 200/225 amp outfit with the distributor that is built into the back of the 12 volt generator and the crankshaft (about 1 1/8") protruding out the front to hand crank it (read old)...if thats any help in identifying it. I polished the commutator, the brushes looked proper length...but no welder output. Anybody got any suggestions? This old welder has a duplex receptacle for DC output that runs auxillary lights or tools that only put out about 90 volts...thats about all the help I can be...anyone familiar with this old ex-good Hobart portable? Just quit as I was on a welding job...could hear the whine sound go out of the generator and no output after that. Thanks for your comments...Fred OH
T_Bone
11-04-2003 12:54:12
 Re: Hobart portable troubles in reply to Fred OH, 11-03-2003 12:38:47
Hi Fred,
About the only thing I can suggest is a good book on generators as they all work about the same or on the same principle.
This could be anything from a open winding to a bad voltage regulator to the windings having to much moister content.
T_Bone
Fred OH
11-04-2003 13:09:16
 Re: Re: Hobart portable troubles in reply to T_Bone, 11-04-2003 12:54:12
Thanks T_Bone...Just thought maybe someone had one with the same problem and knew where to look first. I'll look around the Hobart Board or tear into it and start testing things. I do know where theres another just like it to compare things with. Fred OH
