Tool Talk Discussion Forum
O/T Tools and their Uses
Tim...OK
11-03-2003 10:19:39
Tools Explained (thought you guys might enjoy these)
Here's a list of tools and their typical usage. Anyone who has spent time working on cars will be able to relate to this.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive car parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing convertible tops or tonneau covers.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling rollbar mounting holes in the floor of a sports car just above the brake line that goes to the rear axle.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting those stale garage cigarettes you keep hidden in the back of the Whitworth socket drawer (What wife would think to look in there?) because you can never remember to buy lighter fluid for the Zippo lighter you got from the PX at Fort Campbell.
ZIPPO LIGHTER: See oxyacetelene torch.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used
mainly for hiding six-month old Salems from the sort of person who would throw them away for no good reason.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against the Rolling Stones poster over the bench grinder.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Django Reinhardt".
HYDRAULIC FLOOR JACK: Used for lowering a Mustang to the ground after you have installed a set of Ford Motorsports lowered road springs, trapping the jack handle firmly under the front air dam.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor Chris to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup on crankshaft pulleys.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and hydraulic clutch lines you may have forgotten to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin", which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round-out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty suspension bolts last tightened 40 years ago by someone in Abingdon, Oxfordshire, and rounds them off.
Paul Janke
11-08-2003 10:32:15
 Re: O/T Tools and their Uses in reply to Tim...OK, 11-03-2003 10:19:39
Trouble lights are one of those things which don't follow the rules of physics. The light output is always less when it is directed toward what you want to see, then increases by a factor of ten or more when it swings around on its own to direct the light into your eyes. Also, a 40 watt light will always direct 500 watts of heat into the reflector/shield when it touches skin.
Chris-se-ILL
11-04-2003 18:51:02
One of my favorite tools is the "cresent-hammer"!!! It is designed to be adjusted to a similar size as the nut/bolt/flange that you want to us it to loosen/tighten... but will never fit exactly so you can easily round the shoulders off of the nut/bolt/flange... and then the large heavy end of the cresent-hammer is just the right size to give whatever is in your path a good "whack" or two!!!
Mike
11-04-2003 16:14:04
E-Z OUT:Tool made to extract money from your wallet and blue words from your mouth(and still harder than ANY drillbit known to man).
70G
11-04-2003 08:39:10
STUD REMOVER: Used for destoying threads on threaded studs, works especialy well when used to install new studs
BOLT CUTTER: Shoots broken bolts and nut throught the air at high speeds, works best when used close to the wifes car.
Roger
11-03-2003 19:06:11
CIRCLIP PLIERS: A mechanical device used for floor inspection. Works by propelling a circlip as far away as possible, at the greatest possible speed. When you hear the slight tinkle of the circlip hitting concrete, you know it is time to inspect your floor. Works best with circlips of odd sizes guaranteed NOT to be at your local fastener supply house. Urgency of repair greatly enhances the floor inspection process.
CWL
11-04-2003 06:53:40
 Re: Re: O/T Tools and their Uses in reply to Roger, 11-03-2003 19:06:11
Those are even more fun during "in field" repairs. The limits of the distance the clip will fly outdoors are endless!
Fred OH
11-03-2003 12:57:42
You could also add the lowly 12 point combination wrench...used to place on water pump bolts and ruin knuckles...right before you raise up quickly and smack the back of your head on the radiator bracket/hood latch holder...and then bite your tongue. This was on an old 58 chevy and it happened to me...just that way, twice on the knuckle part. I might have been the one who started the saying "this Buds for me" Fred OH
Jailkeeper
11-03-2003 10:44:45
Thanks Tim!! Yep, most of those sound familiar.
