Tool Talk Discussion Forum
Tractor tire removal
Venda
11-02-2003 16:41:06
Is there a good way for a hobbiest to change rear tractor tires? I once saw an add for a screw type bead breaker sold by Gemplers in Mt Horeb Wisconsin. Does any one know if this tools works?
Any other tools made, that help, or do you have to call the experts to replace the rear tires?
Joe Bogart
11-06-2003 17:03:03
 Re: Tractor tire removal in reply to Venda, 11-02-2003 16:41:06
I take the tire off the tractor lay it on the ground, put a 3 or 4ft square tubing under the tire going toward the center hole of the rim, run a chain through the square tubing, come up through the center hole, now above the tire, I then use a farm jack from TSC or Qualty Farm they sell a 7,000 pond lifting jack, price is about 35 dollars, I then put the base plate of the jack on the bead, connect chain above jack lifting arm, when you start jacking against the chain all the pressure is concentrated on the bead. I have never had a tractor tire that I could not break in a few minutes or less using this method. If you don't use the square tubing it usually won't work because the chain push the outer edge of the tractor tire into the rim.
Joe Bogart
11-06-2003 17:01:03
I take the tire off the tractor lay it on the ground, put a 3 or 4ft square tubing under the tire going toward the center hole of the rim, run a chain through the square tubing, come up through the center hole, now above the tire, I then use a farm jack from TSC or Qualty Farm they sell a 7,000 pond lifting jack, price is about 35 dollars, I then put the base plate of the jack on the bead, connect chain above jack lifting arm, when you start jacking against the chain all the pressuer is concentrated on the bead. I have never had a tractor tire that I could break in a few minutes or less using this method. If you don't use the square tubing it usually won't work because the chain push the outer edge of the tractor tire into the rim.
Alvin n Ms.
11-05-2003 10:35:49
I repair the large ones without removing the wheels. I have a slide hammer from KD tools that works fairly well. Trucker supply sells them and other good tire repair supplies. I never ever ever ever have seen a lady repairing tires. Come forward if you are guilty.
T_Bone
11-02-2003 19:16:00
Hi Venda,
I use a wedge from a wood splitting maul head with a 4lb hammer. Set the maul edge on the tire just above the rim edge at 45* and give it a frim tap, move 4" and repeat. The bead will break all around after about 16" then it's time to do the inside bead, same procedure and will pop the bead in about 10" or so. Very easy to do.
I bought a 12" and 24", 7/8" hex crow bars (about $8eh) from HD then sanded the sharp edges round. They make excellant tire irons. Work small areas, about 4" long to get the bead over the rim, the same to reinstall the tire.
I use a SS wire brush on a cheap drill motor to ruff the tube/tire for patching, then use liquid buffer (NAPA), then cement, then patch, then roll the patch with a screen door roller.
Patchs and cement at Wal-Mart as there much cheaper than NAPA. I've also used this same method for my LT235R85/16 tubeless on my dully drop center rims. Although more difficult than a rear tractor tire, it can be done easy.
By the time I change to a spare, drive to town, wait to have it fixed, I can be done and drinking coffee for a hour. It was the $75 (each tire) travel charge for the tractor tires that got me started tho.
T_Bone
john nelson
11-02-2003 19:13:06
I have used regular truck tire tools, like bead breaker hammer and tire tools. A few times even had to use jacks to break the bead loose, they can be quite rusted and stuck. Older tires are stiff and hard to handle. How many of you guys have used either (starting fluid) to seat the bead on tubeless tires, it works, but i don't recomend it.
John
Alvin n Ms.
11-06-2003 20:09:19
 Re: Re: Tractor tire removal in reply to john nelson, 11-02-2003 19:13:06
A little gasoline (Fumes) will pop the beads out also. I made the mistake of trying to install a valve core and got my fingers burned. Didn't tell my mother n law. I have seen several home made blaster air tanks. Just a tank, with a large pipe with end flatened and a valve to release a large gush of air. Will scare your dog.
Larry
11-03-2003 15:35:40
We do that all the time on our skid steer loaders.
Works great, just don't sniff too much b4 lighting!!!
Bob
11-02-2003 18:18:23
After you get the tire off, and then bak on, NAPA sells a tool to pop the bead back onto the rim. It is a 10-15 gal air tank with a pipe oout of hte side with a valve. You fill the tank, then get the pipe near the tire and rim, and throw open the valve and the rush of air pops the tire on. You may have to try a few times to get it aimed right, but it does work.
Big Jake
11-03-2003 10:32:43
 Re: Re: Tractor tire removal in reply to Bob, 11-02-2003 18:18:23
Had local co-op out this summer to replace rear tractor tire. He couldn't get the tire to seat, so he grabbed a pail of goop(some sort of grease made for this application) & slapped it on all around the tire & rim. This blocked the air from escaping & presto the tire seated itself. As the tire was aired up it squeezed out most of the goop which he recovered to use again
dhs
11-02-2003 18:40:42
Been using this tool on my truck tires for years but I never knew it would also work on tube type tractor tires.
JD-Tractor
11-02-2003 18:36:49
Hey Bob!!Are you for real ? And I,m not being a smart alex .That must be a neat trick .I'd even pay to use that!!
Bob
11-02-2003 18:59:25
 Re: Re: Re: Tractor tire removal in reply to JD-Tractor, 11-02-2003 18:36:49
LOL yes I am for real, as is the tool. Made by a division of Gates co, the old Schrader-Bridgeport Co.
T_Bone
11-02-2003 19:19:46
 Re: Re: Re: Re: Tractor tire removal in reply to Bob, 11-02-2003 18:59:25
Hi JD,
Ya, the bead blaster works well but besure and wear ear plugs when you watch. WOW!
T_Bone
jake
11-03-2003 20:04:05
 Re: Re: Re: Re: Re: Tractor tire removal in reply to T_Bone, 11-02-2003 19:19:46
Gemplers has a tire lub by the name of "no rim rust", This compound does not dry out and future dismounts can be done with the wheels still on the tractor. I mounted 2 38X13.6 with 2 18" tire irons in 20 min. Another aid is a valve stem puller about 3.50.
old
11-02-2003 17:25:11
they make a hammer just for brakeing beads I have two of them its hard work but saves a lot of money in the long run they look sort of like a spliting maul that is turned 90 degrees and bent a little most farm supply houses have them hope this helps you also you should by a couple tire irons they are about 3 foot long and flat on one end and a strange curve on the other
Rod (NH)
11-02-2003 16:51:04
Hi Venda,
Yes, the Gempler's screw type bead breaker works nicely although it is fairly expensive for using only a few times. I have done it different ways. One is with sledge hanmmer and wedges. Another is with down pressure from a tractor bucket. The easiest way though is with that bead breaker. Plus it is usually possible to easily break both beads without removing the rim from the tractor with that tool.
third party image Rod
Alvin n Ms.
11-02-2003 20:53:29
 Re: Re: Tractor tire removal in reply to Rod (NH), 11-02-2003 16:51:04
Makes it a lot easier, when you use some of moms dish washing soap, breaking the bead, plus the bead will go back on with a lot less air pressure.
Tires can be dangerous with over inflation to push the bead out. Been there, no soap. No tire repair for me. For very stubborn, like old tires shrunk FROM OLD AGE I use my backhoe to break the bead. Never failed me so far.
