Tool Talk Discussion Forum
Oiless compressor question, calling roger
chris smith
11-02-2003 14:47:05
Got a campbell hausfeld oiless compressor, 3.5 horse motor 11 gallon tank. From empty tank to kick off takes just over 2 minutes. From kick on to kick off takes a little over 30 seconds. Do these times sound pretty good?? Or do they sound like the pump is getting tired??
Thanks!! chris
Roger
11-02-2003 17:24:30
 Re: Oiless compressor question, calling roger in reply to chris smith, 11-02-2003 14:47:05
Sounds good to me. If in doubt, pop the cylinder head off. You'll see right away if the cylinder is scored or if the valves are weak. Junk the old ones and pop in the new. No rebulding on these pump, strictly remove and replace.
chris smith
11-03-2003 11:55:38
 Re: Re: Oiless compressor question, calling roger in reply to Roger, 11-02-2003 17:24:30
I am pretty sure the cylinder is scored some, i could see a little and if i squirt some oil in the intake while running you can see it blow out the bottom. Oh well, use it till it blows then fix. I got it cheap, and it is my beater compressor. Different note, any idea how much to rebuild this ch??
Thanks roger!! chris
