Tool Talk Discussion Forum
3.8L Chrysler question
Gene
11-02-2003 05:37:45
I just picked up a 99 Town & Country minimvan with a 3.8L v6. I have gone through the owner's manual three times and can find nothing on fluid capacities (crankcase, cooling system, gasoline tank). I can't believe Chrysler would have an owner's manual w/o this stuff. They do however have fuses and bulb sizes, whcich surprises me.
Anyway, I assume that the crankcase capacity is five quarts, with a filter change, for the 3.8L, is that correct? Thanks in advance. Gene
Kevin
11-03-2003 17:42:11
 Re: 3.8L Chrysler question in reply to Gene, 11-02-2003 05:37:45
Yep 5 quarts right to the top. Our '96 has 155k on it, no adding between changes, 3200 miles. Good engine, now the transmissions can be a different story...
RJ-AZ
11-02-2003 06:06:12
That power unit is 5 quarts with a NAPA 1085 filter (or equivlent).We are running some in our fleet that have almost 200k miles on them. Check the A/C V-belt and Serpentine belt and maybe go ahead and change then out now.
Coach James
11-02-2003 09:13:21
 Re: Re: 3.8L Chrysler question in reply to RJ-AZ, 11-02-2003 06:06:12
The Autozone website will give you all the fluid and gap specs. for your vehicle as will the Advance Auto website.
Coach
