Tool Talk Discussion Forum
Goosneck
Jack
10-31-2003 13:51:50
Found a deal on a Featherlite gooseneck trailer.Any one have experience with them.Good or bad.
thanks
Dr Cy Kosis
11-01-2003 07:10:38
 Re: Goosneck in reply to Jack, 10-31-2003 13:51:50
Featherlite is a top shelf product.
Be aware that ALL aluminum trailers big or small will develop fatigue cracks over time with heavy use. Once that starts its expensive to repair and keep them up from then on. Either you pay some one $70+ an hour to repair them of buy the specialized cutting and welding equipment and learn to do it yourself.
Fatigue cracking will never be a problem for most non commercial users. It occurs mostly in situations where the trailer is loaded heavily the majority of the time and is used a lot....like daily. I've seen brand new aluminum rock trailers begin cracking in just a matter of months.
In your case inspect the neck very carefully before buying. Thats where the stress is the most concentrated. If you get it take time every so often to inspect it for cracks as well.
Joel Harman
11-01-2003 15:01:41
 Re: Re: Goosneck in reply to Dr Cy Kosis, 11-01-2003 07:10:38
Now I was just told the opposite - better to have a load than run around empty all the time. I will agree that if one overloads all the time this will cause problems.
Point the quality control guy was trying to make to me was don't run gravel roads empty alot. Trailer will not flex as much if it has a load.
Since everyone here assumes you are asking about stock trailers I'll ad more. Riveted trailers are better than welded ones. They flex more.
Featherlite stock trailers could use more reinforcement around the rear door.
Keep whatever aluminum stock trailer cleaned out as urine is hard on the floor.
Dr Cy Kosis
11-01-2003 17:17:44
 Re: Re: Re: Goosneck in reply to Joel Harman, 11-01-2003 15:01:41
I understand the concept that he's working off of in that the empty unit would be more subject to bounce and the subsequent vibration through the structure. I think it would also tend to make a difference as to whether the trailer in question was a "prestressed" design or not.
Nearly all of the large aluminium semi trailers are now on air ride systems. They aren't on air ride for driver comfort, they're on it to reduce shock loads to minimize fatigue cracking. I've also noticed most of the new aluminum stock trailers I see are on a torsion axle system, rather than leaf springs probably for the same reason.
Me? I wouldn't worry about buying an aluminium trailer..... other than writing the check. I keep thinking about buying extrusions and plate and having pieces sheared and broke to assemble me a custom aluminium equipment trailer. The only thing stoppping me is the material price is just hard to justify on small scale and part time use. I doubt I could save but about 500 lbs on a 20 ft trailer the same size but it would sure be neat to have.
Joel Harman
11-02-2003 07:33:19
 Re: Re: Re: Re: Goosneck in reply to Dr Cy Kosis, 11-01-2003 17:17:44
Had a 16'econolite(featherlite's steel line), 6'8"wide 6'6" tall, wood floor, #4200 empty Have a 20'charmac, 8' wide, 7'tall on dexter #7K torsion axles, #3800 empty.
deadeye
11-01-2003 07:05:44
Not sure what you need to know if you think you found a good deal. Buy it!!! It's like anything else, if you take care of it and don't abuse it, it will last a long time. I was the QC manager at Featherlite for 5 years. I've seen some bad things happen, but the majority of the products that Featherlite or Alumiline both put out are good products. They are two different companies, built in the same Northeast Iowa town both producing quality products.---deadeye--Retired.
RJ-AZ
11-01-2003 06:18:47
My niece and her husband have two of them they use for straight hiway use. Must be OK as she got stopped for doing 92 MPH in WYO last month. I was kidding her about that and she told that ol' aluminum trailer just sticks out like a flag in a hurricane. I have heard they will develop cracks if used hard on back country washboard roads.
Greywolf
11-01-2003 05:35:16
Featherlite is one of the premium brand name in horse trailers. Not sure about any of their other lines.
rustyfarmall
10-31-2003 16:56:07
No personal experience, but the featherlight livestock trailers seem to have a pretty good reputation.
