Tool Talk Discussion Forum
pressure washer heater
keyman
10-30-2003 15:50:53
Has anyone had any experience with the high pressure water heater from Northern?
Suppose to be able to use your high pressure washer and run your water through this heater so you have high pressure hot water.
Green_in_MI
11-03-2003 17:43:35
 Re: pressure washer heater in reply to keyman, 10-30-2003 15:50:53
I would read the instructions for your machine closely for what it says about hot water use before you go raise the temperature. Mine says to use only cold water.
sherburne
11-03-2003 06:30:05
I've been thinking about one myself. Seems like a good idea. If you hear anything offline, please let me know. I have a 4 gpm at 4000 psi with Honda 13 hp and Cat pump. closeout at Lowes
with another 10% off for opening a charge. $900
