Tool Talk Discussion Forum
Miller welder help 1959
Ivan
10-30-2003 14:56:53
I have an old Miller Arc Spot powered by an Onan CCK . I'm having trouble with the ac generator running wayyyyy y out beyond spec . Ok , what I know ,although the tag is badly faded . Its a mod 200 c ser E26942 . At slowest speed last night it was putting out 135 volts and barely running . This was loaded with about 1400 w load . Bump up the throttle just enough to get it running smooth and its putting over 200 volts out of a 110 socket . I did some work today to the carb and got it smoothed out to where it will idle real nice . But what about the regulation ? I know it has to run at 1800 rpm to get 60 cycles . I tried Miller online and they said no dice , try a distributor for something that old . I know these machines are not real precise on voltage and I want it mainly for lighting .Thanks ,Ivan
Mike
10-31-2003 18:20:16
 Re: Miller welder help 1959 in reply to Ivan , 10-30-2003 14:56:53
Go to hobartwelders.com, post your question on weldtalk and you will get a response from one of the hobart experts. You may have to register to post. Cool site, good people.
Mike.
Glen in TX
10-31-2003 14:06:45
Most local dealers offer service or can refer you to someone that services Miller and others.
T_Bone
10-30-2003 15:53:06
Hi Ivan,
A good service manual on any self-excited generator would work well for a understanding of how the system works.
After reading the service manual, then reread your post and you'll see where you've already diagnosed the problem.
T_Bone
