Tool Talk Discussion Forum
sealing 2 stroke crank case without a gasket
munch
10-30-2003 12:33:57
i am rebuilding a chainsaw engine and am unable to get a new gasket for crank case. has anybody any ideas or tips on how i can seal crank case.
munch
11-02-2003 02:52:47
 Re: sealing 2 stroke crank case without a gasket in reply to munch, 10-30-2003 12:33:57
thanks for all your help guys.hope to try some of your answers out.
Jim
11-01-2003 10:00:18
I worked in a bike shop for about 10 years, the best stuff made was called yama-bond, it was better than anything on the market including loctite gasket eliminater.
Indydirtfarmer
10-31-2003 09:44:53
Twenty years ago, I might have been known as IndydirtBIKER. I raced enduro's and hare scrambles. I worked on all my own bikes, and NEVER used case gaskets. I used a product that is STILL available through Yamaha dealers, called Yama-bond. It comes in a toothpaste tube, and doesn't cost very much. It is good stuff. and doesn't break down with gas or oil. Good luck, John
hacker
10-31-2003 00:37:02
when i was younger i used to work on alot of motorcycles and we never used anything between to 2 halves of the crankcase.just lightly sand them to get them clean and reassemble it
Bob
10-30-2003 23:18:29
Permatex Anaerobic Form-a-Gasket compound, small tube, part #51817.
Bill
10-30-2003 19:40:39
First I would check to see if the engine case had a gasket or it might be a machined fit. I work on motorcycle engines and most have no center case gasket, in this case we use Avaition Form a Gasket by Permatex. This will seal without getting cemented or permently stuck together.
RJ-AZ
10-30-2003 19:09:55
There is a product made by Loc-Tite called gasket eliminator that I use on VW case halves.
JerryU
10-31-2003 10:35:29
 Re: Re: sealing 2 stroke crank case without a gask in reply to RJ-AZ, 10-30-2003 19:09:55
Use this all the time on motorcycles, 4 wheelers, and almost anything else. Was skeptical at first, but once you use it, you will be sold. Just don't hog everything down supertight so there is some sealer left in there.
JU
Mac
10-30-2003 13:59:34
Yep getcha some gasket material, they aren't hard to make. I'd use a little RTV cement on the gasket when re-assembling.
John
10-30-2003 13:51:32
get a sheet of gasket material that you can cut to fit
Slowpoke
10-30-2003 22:19:00
 Re: Re: sealing 2 stroke crank case without a gask in reply to John, 10-30-2003 13:51:32
Sometimes adding gasket material to a case that is machined to fit without a gasket can cause problems by making the case halves farther apart.
navara
10-31-2003 02:50:07
 Re: Re: Re: sealing 2 stroke crank case without a in reply to Slowpoke, 10-30-2003 22:19:00
thanks for everybodies help will try some of these ideas.
stihltech
10-31-2003 03:56:17
 Re: Re: Re: Re: sealing 2 stroke crank case withou in reply to navara, 10-31-2003 02:50:07
Compare the old gasket to the new material. Match it as close as possible. Most saws I have worked on use a thin gasket material.
